C hydraulic Cylinder?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=121384
Printed Date: 05 Apr 2026 at 2:01pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: C hydraulic Cylinder?
Posted By: AJ
Subject: C hydraulic Cylinder?
Date Posted: 03 Apr 2016 at 8:56pm
How hard is it to repack the cylinder on a C?
------------- Can't fix stupid
Posted By: Dakota Dave
Date Posted: 03 Apr 2016 at 9:14pm
Unscrew the end slide the packing nut off the end. Pull he old pickings out put the new ones in and screw the packing nut back on. Soak the new packing so in oil before using them.ifi rember correctly there should be 4 leather chevron seals in it. If the Ramos in fairly good shape it'll take you about 30 minutes.one of the ones I did was so bent it would Bailey move. I straightened it on a hydraulic press till it rolled on a flat table and put back together. Since there are several seals even a lightly pitted ram will seal well.
Posted By: AJ
Date Posted: 03 Apr 2016 at 10:10pm
Ok. I'll give it a try then. Agco carry the seals?
Date Posted: 03 Apr 2016 at 10:19pm
It's been quite a few years since I got seals for a c but I did get seals for a WD 45 two years ago and they were $14 a set.if you don't have a local AGCO dealer try sandy lake. They have been helpful in the past they got me a NLA part
Posted By: LeonR2013
Date Posted: 04 Apr 2016 at 1:22am
AJ there's a hydraulic place in Mexico that keeps all kinds of things like that to repair cylinders, jacks,and even make parts, and they are good. By the way I left a message for you earlier for a 45 rocker shaft if you have one. Thanks. Leon R Cmo
