C Headlights
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: C Headlights
    Posted: 07 Apr 2012 at 5:44pm
It didn't have any when I got it and there was NO wiring, I had to start from scratch. I want to put some on my 'C'. I want to know how they are hooked up and where the wires run?  I don't want to get the wiring in the fan blades. How do they unhook when you want to take the hood off?  Anybody have any pics?
Thanks, Ted
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 5:59pm
  they are wired into a block on the fan shroud -- does not effect hood removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 6:12pm
If I remember right, my CA had an insulated stud toward the left side above the fan. The right side light's wire crosses to this and both are connected to the supply wire on the stud. That connection must be broken to remove the lights if you want to remove the hood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:29pm
Where did the supply wire run?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:32pm
That is a good question. It runs in the harness to the generator and then up to the stud.
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:44pm
On Steve B's harness the power wire runs behind the gen and carb thru the tool box to the switch
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:49pm
The hood has a "C" cutout to allow you to remove the hood and not remove the lights.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 7:49am
Chalmersbob, I don't think mine has that?  I will have to take a look.  Thanks!  Do you have a pic of this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:56am
My CA hood does also but you still have to loosen the headlight nut to remove the hood. I have had to take the hood off for different reasons. If I want to operate the tractor with it off I won't do it with the lights flopping around so I take them all the way off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:36pm
The power circuit comes off of the Headlight/Charging switch in the Ammeter panel as AC John mentioned. The main feed wire runs to the insulated junction which is mounted on the Radiator shroud from the H/L switch, and then to each headlight. There usually is a little "C' shaped cut at the front of the hood to allow the hood to be removed by loosening the headlights by turning them out a few times. (with the lamp wire disconnected)  Headlights should thread into the side of the Radiator frame. We have new headlights along with new junction and wiring to make it happen if interested Ted.  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 9:27pm
The headlight "bolt" should have a lock nut on it. This allows the light to stay mounted and just loosen the lock nut to remove the hood. If you want to keep the hood off, just retighten the locknuts to secure the lights. Bob
