C engine crank wick leaking
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Topic: C engine crank wick leaking
    Posted: 13 Apr 2019 at 4:01pm
I put in a new ring gear,clutch, crank seal and rebuilt the oil pump. Assembled and ran, getting drips of oil out of bell housing. Tough to see in bellhousing. Appeared to be crank seal, new seal was felt. I ordered a cork seal and split again. My crank seal is dry, wick on crank is wet. Does anyone offer a new wick or can I eliminate the wick. Pilot bushing is not wet, it is new also.
More than I need
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 4:15pm
I just thought about my comment on eliminating wick, didn't think that one through. How much is to much oil, it is already making a mess in bellhousing.
More than I need
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:25pm
Plug the crankshaft hole and use a sealed bearing if you don't want a bit of drip, every once in awhile. My WC is plugged with a sealed bearing.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:37pm
Maybe Dick L would know the sealed bearing info for the B & C?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:48pm
 Charlie has it: Although it more than that simple. The C tractor only uses a pilot bushing which a dab of grease will last a long time.  Plug the crank hole. Put a speediSleeve on the spiral groves on the crank. Use a seal housing and seal from the D10/12/14/15 tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:57pm
It's been a while, but I may have had to bore the flywheel for that bearing, since it just had a bushing in it too. Wacko
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 6:06pm
The flywheel would have to be sent to a machine shop to bore it out for a sealed bearing. Not worth the effort. Those bushings will outlast the person now driving the tractor with the wick hole plugged.
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 7:13pm
Is the wick hole pressurized? 1/8 pipe plug is to small. Called around for a pound in plug, no luck. If is not pressurized I might put in epoxy
More than I need
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 7:54pm
If you want to plug the hole,  just insert a tapered cork after pulling the wick out.
Edited by littlemarv - 13 Apr 2019 at 7:54pm
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 9:00pm
 I drove to a machine shop every work for day and ran a lathe of some sorts most of the time.
 It didn't cost me anything, but a few minutes of my time after hours Wink
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 9:14pm
I put in a cork with a little Indian Head gasket shellack on my B and WC. If you want to replace the bronze pilot bushing and your closer to a case IH dealer it's the same as a Farmall C I believe. I'm 15 min from IH dealer and hour from an Agco dealer.
Edited by oldways - 13 Apr 2019 at 9:15pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 9:54pm
There might be some details in the shop manual:http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 11:18am
Great! I own a custom mold shop started in 1997 that was once a three man shop as well but most people don't.
Went down to a one man and myself when I bought these in 2002.
Edited by Dick L - 14 Apr 2019 at 11:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 11:30am
Nice setup, I would live in there. Thumbs Up
pcheffernan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcheffernan Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 6:32am
The wick is there to lubricate the pilot bushing. It is supposed to leak oil on it. Old school technology. They quit doing this many years ago, and now lubricate with grease. Probably not as effective but less of a mess.
This page was generated in 0.067 seconds.
