c #5 plow |
54f250 ![]() Bronze Level ![]() Joined: 09 Dec 2022 Location: 47135 Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Dec 2022 at 3:25pm |
I just bought a 1940s C with a mounted plow -- I believe it is a #5 plow. I am missing one mounting bar. The lower front draw bar (connects to the front of the plow tongue) is connected to the upper lift arm by a piece of flat stock steel. I can make one but I don't know any dimensions. The bar has one 5/8 inch hole on one end and four 5/8 inch holes on the other.
If anyone has one, I need to know how long the bar is, how far apart the holes are, etc. I have a manual with pics but no dimensions. Any help would be appreciated.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5146 |
The mounted plow for a C is a B&C Pickup plow not a #5. Asking for something to fit a correct implement will go a long way to getting the correct part.
The vertical connecting link from the plow drawbar to the adjusting link would be part #309928. I no longer have any B&C plow frame parts around to give measurements. The upper end will have 3 holes.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1345 |
My Model C plow is out behind the barn under 3 feet of snow with more snow coming down. If you can wait a (long?) while I will get a measurement for you.
Thanks. We don't have snow here -- yet -- but I don't think I'll be trying it out soon. When you get rid of the snow, I would appreciate it.
Thanks again, jim
Paul,
Thanks for the info. I couldn't find much about this plow -- just a mention of a #5 and #6. The part number should be helpful. jim
Jacob (WI,ND) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1248 |
If nobody gets you the dimensions first, I'll measure up my C plow piece when I'm back home in WI over the holidays. I imagine someone will run out to their barn with a tape measure before that though.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
I haven't forgotten about this. Are you still looking for this plow linkage info? If so, the last time I was home I measured mine up, and can text you a pic of a little blueprint so you can build one. Just let me know, send me a PM with your cell number, or Email me with it. My info is in my profile.
Jacob Swanson
