building a puller.
Message Reverse Sort Order
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: building a puller.
    Posted: 23 Aug 2018 at 6:56pm
I pull a WC in farm stock class with the club I belong to. As far as I know mine is factory stock or maybe over size pistons?  I  have out pulled WD45's and WC's with a D17  motor and  38" tires several times.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 4:39pm
Build the WC. For stock or mildly modified type classes this is my favorite model pulling tractor. Many times I've out pulled WD/WD45s with my WCs.
Good Luck!
Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 3:38pm
Buy one already done, sometimes a lot cheaper
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:47am
You could drive up to Casey IL. next pull (aug 5th I think) Several good AC pullers there. You can check out their rides and get some good input. Like bradley said, need to know the rules first.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 1:16pm
Start with your rules and they will point you to the tractor with out the rules it's a guess at best
etcv97 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 1:07pm
I'm thinking about building a pulling tractor to pull as a stock or mild built tractor.. Trying to decide what tractor to use..
I have a wc that would take the least amount of work to be ready or a wd or d17 that needs everything.. But i also have some olivers and 2 cyl deeres i could use also, i prefer to stick with allis as those are what i like best.
So what would be the best to use and what would i need to do to make it competitive?
1958 D17, got a lot more just need to find out what years they are.
This page was generated in 0.152 seconds.
