Building a CA puller
Message Reverse Sort Order
Orange toe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange toe Quote  Post ReplyReply Direct Link To This Post Topic: Building a CA puller
    Posted: 21 Jul 2023 at 7:22pm
I have a set of 16.9 x 28 firestones they are wore down to about a half inch tread just wondering with pretty much stock engine carb work , manifold work , would they be to much tire? the rules around our area are you are either farm stock or modified no real mile per hour rules except at a couple pulls
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange toe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 7:03pm
Thanks Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 8:19am
The service manuals give a detailed description of rebuilding the final drives, even the "butt first" I&T ones. Basically remove all the hand clutch parts and install the Left axle in the RH axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange toe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 11:32am
I was hoping someone could help me with the procedure of removing the hand clutch I have a parts tractor with left axle just not 100% clear on how to remove it
