Buford, Ga. pull WD45 diesel
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: Buford, Ga. pull WD45 diesel
    Posted: 07 Nov 2010 at 8:04pm
[TUBE]http://www.facebook.com/l.php?u=http%3A%2F%2Fwww.youtube.com%2Fwatch%samt[/TUBE]
Pull in buford, ga saturday  4500 lb open class   Sam T-Ga.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:23pm
I tried to download youtube video, didn't work. I will try again. It is list as   samt buford ga pull.     Sam T-Ga.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:47pm
[TUBE]Ya9UEMxkmbk[/TUBE]
May be this will work
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:52pm
good pull sam t where is buford ga . just wondering .that is the sled i pull alot on.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:55pm
That tractor sounds amazing.  Thanks for sharing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 9:07pm
Buford is northeast of Atlanta on I-85.  Zion Baptist church has this pull once a yr.  I was 2nd, David Powell with his Big Al  WD  was 1st by a few ft.  I had to ride my rh brake to much.  Sam T-Ga.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 9:20pm
Great video. Good pull!
David Gibson
http://www.darkecountysteam.com
1956 WD45
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 9:22pm
Awesome!
Greg Kroeker
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:11am
That 45D looks and sounds great. Is that a Gleaner cab on the sled?
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:19am
Great pull Sam. Don't know how far away you are but hope you and the tractor can make it to Cumming Ga. this Friday/Saturday for their annual tractor show. If so, I'll see you there. God Bless.
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 8:07am
SWEET, Sam, thanks
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 9:35am
Sams WD45D sounded impressive.  Bob, looking forward to your being at Cumming, GA show.   ML, Buford is 15 miles SE of Gainesville, N of I-85 and SE of I-985.   Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 9:37am
ML, 15 mi SW. Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 5:19pm
Herb, Will see you there. Joe PM'd me  some info this morning and I have my motel reservations made. Will head out early Thursday morning. With decent trip, should be there Thursday evening. God Bless.
David (in Mi.) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David (in Mi.) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 5:31pm
 Nice job, that is no stock 45 diesel, i own one , sounds lilke a turbo on there. I have pulled before and i know mine wouldn't do it in second gear, and i see you pulled it out of second.  Very nice job, do you know how much power that thing is putting out. I am impressed!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:30pm
David, I pulled the 4000 lb class in 3rd gear, I should have been in 2nd. This video is the 4500 lb. I was in second gear. Sled wanted to pull me to the left and I had to ride the rt brake to much. I needed a block when I started building engine, all I could find was a gas 262 from a combine, I used the gas grank & cam, org rods and head, so I am 262 cu.in. And it was around 12 psi boost when the frt wheels came off the ground.  I don't know the hp, PTO gear was in tool box with 1/2 the teeth missing when I got the WD, so I took rest of PTO & hyd off to lose weight. No way to check hp. High idle no load is around 2800 rpm. It's my Toy Tractor and I have fun playing with it.   Sam T-Ga.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:48pm
Good Work Sam !!!
