Buda diesel starting habits |
Post Reply |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7379 |
Posted: 27 Sep 2010 at 9:40pm |
Is it normal for a Buda diesel engine to require 3 or 4 cranks to start up when cold on a 50 degree day? A few years back, I remember seeing a different one needing more attempts. Once started, the engine runs fine.
Does this indicate any injector problems or major repairs?
Thanks.
DanNESD
Silver Level Joined: 22 Oct 2009 Location: Milbank, SD Points: 182 |
Mine takes quite a bit to get started but once it starts it runs great.
Eldon (WA)
Orange Level Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Very rare to see a Buda diesel without a can of ether in the tool box.....use it sparingly!
ALLIS EXPRESS!
This year: |
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4526 |
I have a D-15 and two D-17 with Buda diesels. It's normal for them to need some preheat in the manifold and some cranking to start. They will also run a little rough for a minute or two. I never use ether to start because of the indirect injection design head. A Buda engine will give lots of good service if you follow the rules; Leave it warm up before putting it to work, Leave it cool down before turning it off, Don't turn up the pump.
GregLawlerMinn
Orange Level Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Mine does not want to fire when below 40F. Installed a tank heater (my preheater button is froze and have not gotton around to fixing/replacing it) and plug it in when temp cools down. after 15 mins-1/2 hr it fires right up W/O ether and exhaust is pretty clear. I also don't like to use ether for starting.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Jeff Z. NY
Orange Level Joined: 11 Sep 2009 Points: 7326 |
If the rings are sealing really good giving the cylinders good compression the engine will start with less revs than one with poor rings and lower compression.
Better compression makes more heat in the cylinder than an engine with lower compression. Edited by Jeff Z. NY - 28 Sep 2010 at 9:05am |
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Sounds like mine before I took it apart to fix a head gasket issue. At 50 degrees it started fine but smoked a fair amount for 10-20 seconds. Any colder and it would blubber but still start fine. Like Eldon says, be very sparing on the ether or plug it in. You could do a compression test on it if they will let you.
BobHnwO
Orange Level Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
My 7060 and D17D always start hard below 50,but my 1962 Case Diesel TLB will fire right off at 20 degrees with no heat or ether.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
Best starting older diesel I've been around is a 1973 1066. Starts almost like a gas engine. Don't care for the rest of the tractor though.
Wink I am a Russian Bot |
D-17_Dave
Orange Level Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
The thing to remember about the Buda diesels is they are based on the Lanova head design which has indirect injection AND the power cell. Since the power cell bleeds off a small amount of compresion it makes for a somewhat tempermental engine to start when the temps take a dip. The power cell is designed for torque and high efficiancy as the late model diesels were designed for easy starting.
Other things that contribute to good starting are good batteries, real good battery cables, and an injection pump thats capable of delivering proper fuel flow at low rpms. A worn transfer pump in a Roosa-Master pump can require several wasted revolutions to get fuel into the rotory head to fire the injectors. Just some stuff to think about.
j.w.freck
Orange Level Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
anybody with a buda engine in a wd-45,the best investment they can make is a block heater.the engine is a 50 degree or above engine.once running its a whirlwind.
Jason(OH)
Silver Level Joined: 11 Sep 2009 Location: Jeromesville, O Points: 188 |
My dads starts hard below 50 degrees also. We NEVER, I repeat, NEVER use ether to start it. Too much time and money wrapped up in the engine to possibly do damage with ether. What we did was remove the pre-heater from the pre-heater chamber (it didn't work any way), and use a small propane or mapp gas torch, stick the tip of the torch in the chamber for a minute or two and allow the torch to heat the air in the intake manifold. Fires up every time. On really cold days though, we have to hold the torch there for a couple of minutes until the engine warms up. |
j.w.freck
you are right jason,as it states in the ops procedure,to remove the cap on the intake and use an asbestose swab soaked in diesel fuel and ignited.crank the engine over with it drawing the flames into the intake manifold.or you can relocate in texas where you dont need to use that procedure..
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33901 |
On the 45 or early D17 diesels we used a milk strainer pad and just put a whiff of ether on it and then opened up the plug on the side of the manifold and started cranking the engine and just brought he pad up to the hole and it just sniffed the ether off the pad and that was all it would take to start it down to -20... winter weight oil and good batteries of course. Below that, you better have it close to electricety to plug the tank heater in for an hour and put a blankie on to keep the warmth in. But was best to just use the 170, D17 or the 45 gas for choring instead of trying to wake the diesels up.
Calvin Schmidt
I've never done it or know of anyone who has personally done this, but last week someone told me that soaking a rag is gas and holding in the air intake will start a diesel in cold weather.
ChuckLuedtkeSEWI
Orange Level Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Calvin, I have used that method on my 45 diesel before, but now I do what Jason says. I just pull the plug out by the manifold heater, and put a propane torch in the hole and then start cranking it over. It will start up and depending on how cold it is, you might have to hold it there for 10-15 seconds until the engine will run on it's own. I then let it warm up good before I do anything with it.
Post Reply | |
