Borg Warner S366 -D-21
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: Borg Warner S366 -D-21
    Posted: 26 Nov 2018 at 7:33pm
Is this a good turbo selction for a D-21  , pretty much stock engine and fuel system ..
I am asking for a freind.
BorgWarner S300SX3 Turbocharger 66mm / 2.60" Compressor Inducer Dia. S300SX3 Turbocharger 66mm / 2.60'' Compressor Inducer Dia. 3.60'' Compressor Wheel O.D. 73mm / 2.89'' Turbine Exducer Dia. 80mm / 3.14'' Turbine Wheel O.D. 0.88 Turbine A/R T4 Open Flow Turbine Inlet Straight Compressor Outl
Edited by Beirnesy - 26 Nov 2018 at 9:20pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 7:21am
In my opinion, that is way too big for a basically stock D21. The S200 would be a much better option, easier to fit as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 10:33am
Bolting on a bigger turbo while leaving the fuel delivery (Gallons per hour) and the top RPM the same will probably do nothing but make your once nice tractor to operate a great big turd.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 6:30pm
The 50 year old turbo that is on there is not doing much , so he  may as well put something on that will help  what he has to work with.
concretepumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concretepumper Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 9:19pm
If it has the old rajay/tompson style single bearing charger an upgrade that will bolt right on without cutting the hood and with minor install modifications would be a to4 double bearing charger from a 7080. If it does have the old style turbo, u will need a 210/220 oil pressure/return line and crossover tube. Manifold Exhaust and intake will bolt up direct.
This page was generated in 0.115 seconds.
