boost
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: boost
    Posted: 15 Mar 2015 at 11:39am
What should be a round about boost pressure on 301 with holset hx35 with waste gate tied shut and 12cm exhaust housing
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 6:06pm
When i ran a setup like that it was running in the range of 45-50 lbs with a good cam
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 10:24pm
Depends on the amount of fuel delivered. If you are at 250cc's the boost will be lower than if you have 300 cc's for example - everything else being the same.
Edited by O.P.S. Heads - 15 Mar 2015 at 10:24pm
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2015 at 9:29pm
I am running 410 cc's of fuel and getting 50lbs of boost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2015 at 9:59pm
When I was running that setup I was running around 350 cc of fuel limited to 3000 rpm. That turbo setup worked very well for me. Seemed to let the motor lug well while hanging on to the top end. I think if I remember right mine had a 8 blade compressor wheel on it I think there is a 6 or 7 blade wheel that is supposed to be more efficient although I don't know a lot about that there are others on this site who know a lot more about turbos than me
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2015 at 10:03pm
It seems you have answered your own question. Is this open RPM or limited? Inline or rotary pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 6:27pm
Boost means nothing if you are not flowing air.
