Best paint for rims? |
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Topic: Best paint for rims?Posted: 05 Feb 2021 at 11:46pm |
I need to paint some rims, both AC and other brands, silver color. Anyone have a good paint brand to use that holds up well?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5199 |
Posted: 06 Feb 2021 at 6:25am |
I use Ford Argent Silver. I think it is very close to the original rim color. I'm sure there are other options that are good, too.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 06 Feb 2021 at 7:32am |
Rustoleum Hammered Aluminum is what I have used. Levels out well when applied with a brush and is quite hard when dry.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 06 Feb 2021 at 7:47am |
John,
I would agree with Greg. I like the rustoleum products. I use rattle cans.
We need pictures too! Regards, Chris |
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 598 |
Posted: 06 Feb 2021 at 8:15am |
I have used Allis grey primer and /or rustoleum paint.....both are easy to match later..If it needs to be shiny...use an aluminum paint over as suggested.... |
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1839 |
Posted: 06 Feb 2021 at 1:05pm |
Agco pearl gray.
Darb210
Posted: 06 Feb 2021 at 1:24pm |
rustoleum, painted my 210 wheels & rims over ten years ago & they still look as good as the day i finished them
DIESEL
Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
Posted: 06 Feb 2021 at 9:52pm |
I used Rustoleum aluminum, it looks great.
HD6GTOM
Posted: 06 Feb 2021 at 11:34pm |
I painted the rims on the 1955 WD45 back in 1976 when I first got it. Rustoleum primer and then their silver paint. They still look OK, but they rotted out from the inside out. Replaced them about a month ago with new rims. I hope these last another 70 years. Oh well kid probably won't be able to buy gasoline in 70 Years.
Dakota Dave
Posted: 06 Feb 2021 at 11:38pm |
I painted mine with a product called liquid aluminum. It was had to paint but covered vary well and has held up. https://www.agrisupply.com/aluminum-paint/p/81758/
Edited by Dakota Dave - 06 Feb 2021 at 11:43pm |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 07 Feb 2021 at 9:08am |
I use CaseIH silver. Real close match. Painted front rims yesterday with rattle can.
Rick of HopeIN
Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
Posted: 07 Feb 2021 at 11:38am |
I had good results with hammered aluminum paint also.
JohnColo
Posted: 08 Feb 2021 at 4:00pm |
Thanks for all the great advice guys! The project right now is a Ford 6000 that had a bad tire and the wheel was loose on the axle, and the wheel seal was leaking. Decided I shoud fix it all at the same time. Of course the wheel seal is somewhat difficult to find, although I haven't called New Holland yet. CR still makes them but none in stock nearby, $68!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1612 |
Posted: 09 Feb 2021 at 5:31pm |
I think the best way is to get it powder coated and not very expensive. But you have to disassemble so a bit of extra work.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3672 |
Posted: 09 Feb 2021 at 8:13pm |
Dem-Kote spray can paint makes a great Aluminum(silver) paint. Apply it in very thin coats from a 12-18” distance. It’s nozzles allowed 360 degree movement allowing horizontal side to side to vertical up & down spray patterns.
https://www.grainger.com/product/DEM-KOTE-Dem-Kote-Spray-Paint-in-Gloss-6FGH9 Edited by AC7060IL - 09 Feb 2021 at 8:15pm |
Calvin Schmidt
Posted: 09 Feb 2021 at 8:21pm |
I should have said that all my rear rims are now powder coated. Have a real good local place. Still use the CaseIH silver. The raddle can paint job I talked about above was cream and silver front rims.
Ed (Ont)
Posted: 10 Feb 2021 at 8:49am |
Who does your powder coating Calvin?
Orange Day Farm
Posted: 10 Feb 2021 at 5:17pm |
I use mist silver power coat same as Calvin, best overall finish and very durable.
Orange Day Farm
Clint Worron 30' United, 37' WC, 38' B, 41' C&80 Series cultivators, IB, 51' CA, 42' WF, 49' WD,53' WD&cultivators, 57' WD45&33 Picker, D12, D15HC, 180, All Crop 60, 444 baler, etc... |
Sanchez
Posted: 11 Feb 2021 at 7:54pm |
This wheel was pretty heavily rusted on the inside and needed some cutting and welding around the valve stem. After the repair I had it galvanized at a local shop . I'm pretty happy with the result, the chemical process removed the rest of the rust and restored the factory finish.
Ed (Ont)
Posted: 11 Feb 2021 at 9:06pm |
That’s real nice. I believe they were galvanized from factory.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3987 |
Posted: 11 Feb 2021 at 10:26pm |
That looks real good and will last a lot longer than paint!! Which shop did you use?? I've got a couple from a 'B' I need to do.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 11 Feb 2021 at 10:28pm |
Had mine sandblasted and powder-coated. Immediately after sandblasting, I took them to the powder-coating place. I don't recall the exact color; it was some silver that the fellas at the powder-coating place had a "chip" of. The powder coat cost was very reasonable at $80 for both rims. |
AC7060IL
Posted: 11 Feb 2021 at 10:40pm |
Great work guys. I’ll have to inquire locally about powder coating. Your $80/rim seems reasonable. Thanks for sharing,
Sanchez
Posted: 11 Feb 2021 at 10:54pm |
The shop in Edmonton is Daam Galvanizing, their minimum charge is $90 for 100 LBS, so 2 rear wheels from the WD45 are pretty close to that . As rusty as mine were I figured I would need to sandblast prior to paint , in order to galvanize I wire wheeled the heaviest rust off, then the chemical treatment took care of the rest.
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 529 |
Posted: 12 Feb 2021 at 6:25am |
That's an awesome looking D17!!!
Sugarmaker
Posted: 12 Feb 2021 at 6:51am |
Good looking rims and tractor! John and all of us are getting some good rim options. The take it all apart, repair and sandblast is the best starting point for the coatings. I like the powder coat look on the D17, more of a argent color.
Regards, Chris
