bending cast iron????
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: bending cast iron????
    Posted: 30 Dec 2010 at 9:04am
I have a ca that has a bend in the front steering arm. With it being cast, can I heat it with a torch and straighten it without damaging the arm. Thanks Ron
CA Tractor
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 9:36am
That arm is more likely cast steel. I've heated and straightened the fork on a single front wheel by heating with a rose bud tip and jacking with a port-a-power with good results.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 9:56am
If it's bent, it's not cast iron.  Heat it up and bend it back (carefully).
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 10:26am
I refer to parts like that as  casted iron. Heat and bend or weld with mild steel if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 10:48am
It's probably forged steel, not likely to be cast. Heat it up and bend it back were it belongs. Cast won't bend very fay without breaking.
This page was generated in 0.081 seconds.
