bearing
bs5230 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bs5230 Quote  Post ReplyReply Direct Link To This Post Topic: bearing
    Posted: 29 May 2010 at 8:10pm
i was trying to find where to get a new bearing, it goes on the transmission end of the shaft that goes through the hand clutch- it has a big snap ring on it, the bearing itself goes into the houseing of the trans  this is on a 1951 wd
Edited by bs5230 - 29 May 2010 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:16pm
you can probably buy thru local AGCO dealer or on line AGCO, but the cheapest way is to order from Motion Industiries or Bearing Supply house, etc.. There should be a number on the bearing race and manufacturer such as SKF, FAG, etc. The bearing is not specific to the WD. Most bearings are generic.. In a pinch i have gone to NAPA auto store and they will order it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bs5230 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:25pm
i looked all over the bearing and did not find any numbers or letters at all,  i will try to find it on one of the sites-  i could not find it in the I T manual either
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:35pm
sorry, i donthave a parts book for the WD-- maybe soneones has the number.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 10:25pm
Try taking it to your local bearing shop - if it's more or less in one piece they can measure it and get you going.
WC, CA, D14, WD45
ac612bill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac612bill Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 11:00pm
I have several nos bearings I can look through but I need to know if your serial No. is before or after serial number 127007. I have the one pictured #224837 for the tractors before #127007
