Bearing Help Needed (Bale Chief 302/303)
 Rating: Topic Rating: 1 Votes, Average 2.00  Topic Search Topic Search  Topic Options Topic Options
rlrobinhood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Topic: Bearing Help Needed (Bale Chief 302/303)
    Posted: 13 Jun 2016 at 11:06pm
Hi all,
I'm working on an old Bale Chief 302/303 small square baler.  The plunger arm bearing went out.  Its a spherical bearing with a locking collar and is marked RA108PPB2.  But, I can't seem to find one anywhere.  Does anyone have any suggestions?
Much appreciated!
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 4:52am
Any pictures and dimensions?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 6:00am
I still get some parts for mine from AGCO.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 7:26am
The dimensions are on the top right of this webpage in the grey box.  I just can't find a vendor (in the US).  http://www.bearing-web.com/en/bearing-RA108PPB2-MACDON-112281.html
Again, many thanks!!
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 2:53pm
Looks like a Fafnir no. It will be a 108 with seals on both sides .When you lock collar make sure you lock in direction of rotation.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 4:14pm
I always type any bearing # in Ebay and almost always get it fast and cheap.
http://www.ebay.com/itm/SA208-24-1-1-2-Bore-Spherical-Insert-Bearing-w-Locking-Collar-JD9202-RA108PPB-/301888969603?hash=item4649fc1b83:g:mpIAAOSwr7ZW2f~l
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 7:50pm
What is the shaft diameter? I have an old bearing reference that does not have a ra108ppb2. It does show a ra103ppb-2 with a spherical od. The b-2 signifies a special bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 9:59pm
Here are some pics.  I took some dimensions and this is what I found:
ID 36.15mm and 1.423"
OD 79.98mm and 3.148"
bearing thickness (not including locking shoulder) 22.2mm and .874"
bearing thickness with shoulder 30.25mm and 1.19"
I also found another place where the bearing number was stamped and it is definitely a FAFNIR bearing and the number is definitely RA108PPB2
Edited by rlrobinhood - 14 Jun 2016 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 10:09pm
wbecker, I think you might have the bearing!!  I'll see if I can put my hands on one, but I think this is the right bearing.  I'll followup so future users can use this thread as a reference.  But, if anyone has any other suggestions, let me know.  Thanks all!!
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:38pm
i picked mine up last yr from my massey dealer i'll see if i can find the agco number
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 4:02am
Would be nice to know the AGCO part number, isn't it shown in the AGCO online parts book?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 7:45am
Like I said, just type in the old bearing # in the search box on eBay and it will be there and it will almost always be cheaper than anyone else, and usually arrives in about 3 days.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 9:50am
 AGCO part #70540897.
Part has been discontinued by AGCO.
Try calling Motion Industries as they deal with a lot of bearings.
www.motionindustries.com
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 9:03pm
Nickia, I'd greatly appreciate it.  None of the above bearings will work and no bearing shops can even find my bearing number in their books or computer.  Many thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 9:04pm
Unfortunately, this is the wrong bearing.  It has a 1.5" ID.  I need a 1 7/16" ID.  Thanks though.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 10:00pm
Are you sure there's not a 1-7/16 to 1-1/2 sleeve in the bearing. My bearing reference, Baum Hydraulics http://www.baumhydraulics.com catalog section Q which you can download from that site shows the RA108RRB has the 80mm OD but 1-1/2" ID. The bearings in that family with 1-7/16" bore are RA107RRB and their OD is 72mm. It could very well be that the RA108RRB2 is a special for Allis and not a stock bearing anymore. The thicknesses of the bearings in the Baum catalog don't match your dimensions either, but go look to see what is close.  Same thing in the Shoup spring 2013 catalog. http://www.shoupparts.com
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 11:07pm
 If you can not find the bearing you may need to think out side of the box a little. You may need the have all the mating parts machined to take a standard bearing. May be pricey but still cheaper then buying a different baler.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:35am
Look for fafnir #muob 1 7/16 bearing. Has 1 7/16 bore with 3.1496 od. Listed as a medium series bearing for straight shaft mounting with spherical od.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 12:08pm
I thank that is a spherical bearing that goes in a pillow block bearing.Look for some one that sell millwright equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 3:22pm
I can't tell from pic if od is cylindrical or spherical. If od is flat across then the # is muoa 1 7/16" if it has a radius across then the # is muob 1 7/16". Check with any bearing supplier should be able to supply.
Edited by TMiller/NC - 16 Jun 2016 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2016 at 8:04pm
Did you locate a bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 4:53pm
EBay had both of these bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 11:02pm
Hi TMiller/NC.  I havn't found the bearing yet.  only one side has an extended collar and the OD of the bearing is spereical and goes into a pilblock.
I did order a bearing from AGCO that I'm expecting any day now.  I'm hoping its the right one.  Otherwise, I'm out of luck.  But, my fall back plan is to take a bearing that has an extended collar on both sides and turn down (remove) one of the extended collars.
I'll report back on this.  Many thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:04pm
Hi all,
Thanks for all the information and help on this.  I was never able to find this bearing by cross referencing the number on the bearing (FAFNIR RA108PPB2).  I could never find a bearing with both the correct OD and ID.  When I did find a bearing with the correct OD and ID, it had a double extended race so the race was too wide.
I was able to find the bearing, however, by using the Allis Chalmers part number (70540909) and ordered it through a AGCO store.  I received the bearing and collar today.
Thanks again!!
This page was generated in 0.146 seconds.
