BD262 in a wd
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Topic: BD262 in a wd
    Posted: 15 Feb 2014 at 9:49pm
I have a BD 262 out of a D19 and a wd without a motor. Is it worth putting together? I'm thinking about running a few pulls with it. know I need a diesel adapter plate, hood radiator and to change some linkage. I don't know if the tranny and rear end will work. Any suggestions?
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2014 at 12:32am
you will need to remove some shims from the hand clutch if its a wd45 to make it hold, on a wd that might not be enough to hold it. The trans. will be ok
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2014 at 7:07am
You will need a WD54D flywheel. I have a pattern for the adaptor.
  The weakest link is the final drives.    MACK
This page was generated in 0.040 seconds.
