battery charger desulfator?
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 8:22pm
Rigorous testing of their product is the best way of keeping them honest.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 5:32am
 Well,,I'm hopin ya'll get this figured out and post which one is the best maintainer,,,as I have several batteries I could use one on. I seen the little one at HF but waitin on somebody to shout out if it works out good,,,,,,Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 7:00am
re:...
Two things the Chinlee have no idea how to make, a spring the will hold it's springeness and copper wire that aint brittle or just so skinny it is useless.
You have to remember a LOT of what they make are to the SPECS of whoever is reselling/using the products.
Had a chevy 350sbc /350 tanny on an engine hoist for a 1 1/2, never dropped. I figur ethat's pretty darn good for a cheap hyd cyl 'made in China' !!
What I like is seeing the SAME thing is red, yellow, blue, green at 4 diferent prices !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 12:35am
Joe, had WASTED my money on a couple of them HF ones and wouldn't do that again.  I really like the Schumacher ones.  I've had nothing but good luck with them.  Only had one of them corrode and I don't know if it was my fault of what, but of the 6 I have on batteries now, only one corroded.  I like em cause you can get a 6v/12v
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 7:47am
Well I have to admit I did buy one from HF. At $25.00 it's worth a try. As just a charger it takes a 12v up to 13.9v which is a good float level. I think 6v was 6.9 or 7v. I do like the digital distplay. I don't have a battery down far enough to see if the repair mode will work. I will see if the batteries hold their charge. I will put one in a tractor and see how it goes.
