Barn Door Needs Adjusting
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Barn Door Needs Adjusting
    Posted: 08 Dec 2021 at 1:11pm
Not sure I am up to it this winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 6:07pm
You might be able to take a crow bar and raise it up enough to take the weight off of the affected roller. Unfortunately most all of them rollers require some ladder work, to adjust... Good Luck!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 6:35pm
I took a video and looked it over from my chair and I could see the lock nut on the hanger bolt.  I'll probly set up the scaffolding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 1:03am
Haven't you got some high school kids that live close by who would like to do you a favor?  It sure wouldn't take them long.  I'd come do it if I was closer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 4:36am
If I remember right, there is a flat spot, on the threads of the hanger, and a nut below the roller wheels, tighten the nut while holding the bolt...  Don't remember the sizes, unfortunately...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 6:34am
That is the way it works.  I have it shut and with enough effort can slide it open and closed.  After I put more thought into it I think I can pry the door up and put a block under it to where I can adjust it.  I kept it closed all last winter. Mainly because I had lumber stacked in front as well as the saw.
This page was generated in 0.168 seconds.
