Bareback 190xt |
2wise4agm ![]() Orange Level ![]() ![]() Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Mar 2012 at 1:10pm |
Anyone ever make a 190xt a bareback? I think I'm going to strictly pull mine and could use to shed a few pounds. I can make a cover plate, I'm just not sure if there is going to be a shaft that will need to be supported, or any other issues. Thanks in advance.
Chad (MN) ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: sc minnesota Points: 288 |
I have a XT that is almost a bareback. I has no 3 point or snap coupler. Since it has PTO, I would have to make a cover w/gasket for the rear housing and take out the shaft. Could you order a XT from the factory with no PTO like a D-21??
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Best I can tell by studying the Parts book views, which are lacking at best for a case casting view. I would say no, because the PTO shaft and seal pass through from the rear oil sump, to the front oil sump. That would be the only thing I can see. That being said, I don't know why you couldn't fabricate something by welding up the seal center with some lightweight metal.
Edited by Orange Blood - 02 Mar 2012 at 4:01pm |
Still in use:
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4542 |
I've seen a bareback 200 so I'm sure the same applies to a one ninety. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21878 |
Shove a chunk of shaft the right diameter into the seals and retain it with hose clamps or whatever to keep it in place....can be done without spltting tractor.
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Rubber expandablel freeze plug worked good on my diet d 19
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29816 |
Is it oil resistant rubber on those plugs?
Wink I am a Russian Bot |
