Baler moisture monitor on an AC D15
RP Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RP Farms Quote  Post ReplyReply Direct Link To This Post Topic: Baler moisture monitor on an AC D15
    Posted: 23 Oct 2024 at 7:44am
I am considering putting a moisture meter on  the AC 442 balerthat we have.  It will probably be the agratronix BHT-2 and I believe that it works off of electrical resistance between two sensors and a ground wire attached to the baler.
With the D15 II being a positive ground tracor and not a negative ground, is this going to cause a problem?  I aks here before emaling or calling the manufacturer because I'm sure there is someone on here who has done this.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 8:18am
Your D-15 can easily be changed to 12 volt negative. You simply change the two small wires on the coil, reverse the battery cables and "flash" the generator before you start it.
If you have an ammeter, you will also need to reverse the wires on the meter.
