Backhoe on a D17 Series IV |
A. Drum
Topic: Backhoe on a D17 Series IVPosted: 25 Mar 2010 at 4:28pm |
I'm considering mounting a Ditch Witch 140 backhoe on my D17. Does anyone know what the hydraulic output is on the D17? The backhoe needs 13gpm.
A. Drum |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42095 |
Posted: 25 Mar 2010 at 4:33pm |
Make sure the backhoe will take the high pressure of the AC pump.
Brian G. NY
Posted: 25 Mar 2010 at 4:42pm |
The series IV has modern full time low pressure high volume hydraulics. I don't know GPM but I would think it might be adequate.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 25 Mar 2010 at 8:54pm |
Series IV pump is 10.5 gpm. Not quite enough for your needs.
Posted: 25 Mar 2010 at 9:13pm |
I don't know why it wouldn't work.....maybe a little slower, but until you get good at running it, that might be a good thing. GPM makes for speed, not power.
jrjuday
Joined: 12 Sep 2009 Location: n.e. indiana Points: 119 |
Posted: 25 Mar 2010 at 9:28pm |
I have run a Kelley model 56 with my series IV and it had way more than enough hydraulic capacity. I had to run the tractor at about half throttle or less. The model 56 is the biggest hoe Kelley made, but I don't how it compares to a Ditch Witch. Try it out on your tractor before you buy.
A. Drum
Posted: 29 Mar 2010 at 7:32pm |
Thanks for the help! I'll try it and let post how it goes.
A. Drum |
Dave King
Posted: 29 Mar 2010 at 7:39pm |
We used to run a JD backhoe with about a 9' stick on our 5050 easily enough. I think the 5050 put out about 10 gpm as well. The 5670 my uncle has now will run it faster, but unless you're really smooth, it'll just bounce you around. Like DrAllis said, gpm is just an indication of how fast it will run it.
A. Drum
Posted: 29 Mar 2010 at 7:50pm |
Thanks Dave. The DitchWitch is about 7', so I think it will work too. I'll have to get going on it this weekend...suppose to be warm here in Ohio finally.
