B-125 Cam Events |
| Author | |||
Les Kerf
Topic: B-125 Cam EventsPosted: 19 Feb 2025 at 6:43pm |
I did a mapping of the camshaft timing events on my well-worn Model B-125 Power Unit that came off my Allis-Chalmers Model 60 Combine. I purchased this combine from my neighbor about 40 years ago, and I saw it sitting in his barnyard for about 10 years prior to that. I did observe this combine running in their field combining oats about 50 years ago. I do not believe it has run since then, definitely not since I have owned it. The engine was stuck when I pulled it from the combine this winter; I removed the head and got it un-stuck, it now rotates freely. The head shows evidence of a prior valve job of questionable quality as the valves are sitting at various depths. I suspect the exhaust valves were replaced as they do not appear to have been ground, but the intakes are all rather thin at the margins. The main point being, this is NOT a pristine engine. The #1 Exhaust lobe measures about 0.013" less lift than the others. The valve events are all over the place as well. I ran the cam around at least twice on each lobe and got the same readings, therefore I believe them to be reliable. So be it. I intend to run it as-is anyway when I get the head back on. One interesting observation is the fact that the 0.050" closing point on #1 and #4 Intake are identical at 28 Degrees ABDC and their Net duration is the same at 186 Degrees. Likewise, the 0.050" #2 and #3 Intake closing points are the same at 23 Degrees ABDC and they both have Net Durations of 180 Degrees. Is this just a bizarre coincidence, or did Allis-Chalmers actually go to the trouble of designing a camshaft with different patterns to compensate for the weird firing order of their engines which causes disruptions in the induction system due to the overlap events? Allis-Chalmers Power Unit Model B-125
S/N 72128 B #1 Exhaust 0.010“ Open @ 30 BBDC 0.237“ Lift 0.010“ Close @ 10 ATDC Gross Duration 220 0.050“ Open @ 9 ABDC 0.050“ Close @ 11 BTDC Net Duration 182 #1 Intake 0.010“ Open @ 2 ATDC 0.250“ Lift 0.010“ Close @ 26 ABDC Gross Duration 204 0.050“ Open @ 22 ATDC 0.050“ Close @ 28 ABDC Net Duration 186 #2 Intake 0.010“ Open @ 4 ATDC 0.249“ Lift 0.010“ Close @ 39 ABDC Gross Duration 215 0.050“ Open @ 23 ATDC 0.050“ Close @ 23 ABDC Net Duration 180 #2 Exhaust 0.010“ Open @ 37 BBDC 0.251“ Lift 0.010“ Close @ 13 ATDC Gross Duration 230 0.050“ Open @ 17 BBDC 0.050“ Close @ 8 BTDC Net Duration 189 #3 Exhaust 0.010“ Open @ 34 BBDC 0.249 Lift 0.010“ Close @ 9 ATDC Gross Duration 223 0.050“ Open @ 15 BBDC 0.050“ Close @ 9 BTDC Net Duration 186 #3 Intake 0.010“ Open @ 3 ATDC 0.250“ Lift 0.010“ Close @ 44 ABDC Gross Duration 221 0.050“ Open @ 23 ATDC 0.050“ Close @ 23 ABDC Net Duration 180 #4 Intake 0.010“ Open @ 3 ATDC 0.249“ Lift 0.010“ Close @ 44 ABDC Gross Duration 221 0.050“ Open @ 22 ATDC 0.050“ Close @ 28 ABDC Net Duration 186 #4 Exhaust 0.010“ Open @ 32 BBDC 0.250“ Lift 0.010“ Close @ 8 ATDC Gross Duration 220 0.050“ Open @ 10 BBDC 0.050“ Close @ 12 BTDC Net Duration 178 |
| Sponsored Links | |||
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8580 |
Posted: 19 Feb 2025 at 8:12pm |
Les,
Really nice data on your combine engine. I can now almost relate. On my CA engine my guess is that the old cam would have worked just fine for me. Good luck. Do you have a plan for your engine? Regards, Chris and Cheryl
Les Kerf
Posted: 20 Feb 2025 at 9:39am |
Yes, I plan to install it on a derelict Model C that a dear neighbor and old family friend once owned. This will be a LOW budget project, mostly a labor of love. I was hoping that someone with more knowledge of these engines would chime in with some further insight on the apparent anomaly in the cam timing. Both end cylinders have shorter net exhaust duration and longer net intake duration. Both middle cylinders have longer net exhaust duration and shorter net intake duration. It is difficult for me to believe that this is not by design and merely an accident from wear.
NEVER green
Posted: 21 Feb 2025 at 7:40am |
My guess it a coincidence of wear, I cant imagine AC would have taken the time or money for R&D on a mass produced engine. Like several on here I am disappointed AC never changed the cam on its 426 since its inception.
Joined: 11 Sep 2009 Location: illinois Points: 88632 |
Posted: 21 Feb 2025 at 8:21am |
the numbers Les measured dont seem to show much wear.. LIFT is all very close... Hard to tell if it was really DESIGNED that way... or the manufacturer just had an OOPS in the setup... Maybe happened and not really designed ? ... Dont think the COST would be any different once the setup is done..
Edited by steve(ill) - 21 Feb 2025 at 8:23am |
Les Kerf
Posted: 22 Feb 2025 at 9:56am |
That was certainly my first thought as well. I did some searching and found an old post in which DrAllis states that the WD-45 does indeed have a dual-pattern camshaft, so it is evident that Allis-Chalmers did do some research on that engine and saw a need to go to the extra effort. Of course that does not mean they put the same effort into the B-125 engine.
I also found a thread on the Pulling Forum with some rather lively discussion about camshafts; forum member wi50 wrote an excellent description explaining some of the design issues with the Allis-Chalmers 4-cylinder engines due to their peculiar firing order.
In an effort to wrap my feeble brain around all this, I mapped out the camshaft events on my B-125 engine as follows. I used the 0.010" lifter rise values. ![]() Edited by Les Kerf - 22 Feb 2025 at 10:01am |
