B-125 Cam Events
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: B-125 Cam Events
    Posted: 19 Feb 2025 at 6:43pm
I did a mapping of the camshaft timing events on my well-worn Model B-125 Power Unit that came off my Allis-Chalmers Model 60 Combine. I purchased this combine from my neighbor about 40 years ago, and I saw it sitting in his barnyard for about 10 years prior to that. I did observe this combine running in their field combining oats about 50 years ago. I do not believe it has run since then, definitely not since I have owned it.
The engine was stuck when I pulled it from the combine this winter; I removed the head and got it un-stuck, it now rotates freely. The head shows evidence of a prior valve job of questionable quality as the valves are sitting at various depths. I suspect the exhaust valves were replaced as they do not appear to have been ground, but the intakes are all rather thin at the margins.
The main point being, this is NOT a pristine engine. The #1 Exhaust lobe measures about 0.013" less lift than the others. The valve events are all over the place as well. I ran the cam around at least twice on each lobe and got the same readings, therefore I believe them to be reliable. So be it. I intend to run it as-is anyway when I get the head back on.
One interesting observation is the fact that the 0.050" closing point on #1 and #4  Intake are identical at 28 Degrees ABDC and their Net duration is the same at 186 Degrees.
Likewise, the 0.050" #2 and #3 Intake closing points are the same at 23 Degrees ABDC and they both have Net Durations of 180 Degrees.
Is this just a bizarre coincidence, or did Allis-Chalmers actually go to the trouble of designing a camshaft with different patterns to compensate for the weird firing order of their engines which causes disruptions in the induction system due to the overlap events?
Allis-Chalmers Power Unit Model B-125
S/N 72128 B
#1 Exhaust
0.010“  Open @ 30 BBDC     0.237“ Lift
0.010“  Close @ 10 ATDC      Gross Duration 220
0.050“  Open @ 9   ABDC
0.050“  Close @ 11 BTDC     Net Duration 182
#1 Intake
0.010“  Open  @ 2  ATDC     0.250“ Lift
0.010“  Close  @ 26 ABDC    Gross Duration 204
0.050“  Open  @ 22 ATDC
0.050“  Close  @ 28 ABDC    Net Duration  186
#2 Intake
0.010“  Open @   4  ATDC     0.249“ Lift
0.010“  Close @  39 ABDC     Gross Duration 215
0.050“  Open @  23 ATDC
0.050“  Close @  23 ABDC     Net Duration 180
#2 Exhaust
0.010“  Open @ 37  BBDC     0.251“ Lift
0.010“  Close @ 13  ATDC      Gross Duration 230
0.050“  Open @ 17  BBDC
0.050“  Close @ 8    BTDC      Net Duration   189
#3 Exhaust
0.010“  Open @ 34  BBDC     0.249 Lift
0.010“  Close @ 9    ATDC     Gross Duration 223
0.050“  Open @ 15 BBDC
0.050“  Close @ 9   BTDC     Net Duration 186
#3 Intake
0.010“  Open @ 3  ATDC      0.250“ Lift
0.010“  Close @ 44 ABDC     Gross Duration 221
#4 Intake
0.010“  Open @  3  ATDC      0.249“ Lift
#4 Exhaust
0.010“  Open @ 32 BBDC      0.250“ Lift
0.010“  Close @ 8   ATDC       Gross Duration  220
0.050“  Open @ 10 BBDC
0.050“  Close @ 12 BTDC      Net Duration  178
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:12pm
Les,
Really nice data on your combine engine. I can now almost relate. On my CA engine my guess is that the old cam would have worked just fine for me.
Good luck. Do you have a plan for your engine?
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 9:39am
... Do you have a plan for your engine?...
Yes, I plan to install it on a derelict Model C that a dear neighbor and old family friend once owned. This will be a LOW budget project, mostly a labor of love.
I was hoping that someone with more knowledge of these engines would chime in with some further insight on the apparent anomaly in the cam timing.
Both end cylinders have shorter net exhaust duration and longer net intake duration.
Both middle cylinders have longer net exhaust duration and shorter net intake duration.
It is difficult for me to believe that this is not by design and merely an accident from wear.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:40am
  My guess it a coincidence of wear, I cant imagine AC would have taken the time or money for R&D on a mass produced engine.
  Like several on here I am disappointed AC never changed the cam on its 426 since its inception.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:21am
the numbers Les measured dont seem to show much wear.. LIFT is all very close... Hard to tell if it was really DESIGNED that way... or the manufacturer just had an OOPS in the setup... Maybe happened and not really designed ?  ... Dont think the COST would be any different once the setup is done..
Edited by steve(ill) - Yesterday at 8:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 25 minutes ago at 9:56am
Originally posted by NEVER green NEVER green wrote:
  My guess it a coincidence of wear, I cant imagine AC would have taken the time or money for R&D on a mass produced engine...
That was certainly my first thought as well. I did some searching and found an old post in which DrAllis states that the WD-45 does indeed have a dual-pattern camshaft, so it is evident that Allis-Chalmers did do some research on that engine and saw a need to go to the extra effort. Of course that does not mean they put the same effort into the B-125 engine.
... Duration on a stock WD-45 camshaft is 210 degrees intake and 220 degrees exhaust. A 175 grind is 230/230 duration...
I also found a thread on the Pulling Forum with some rather lively discussion about camshafts; forum member wi50 wrote an excellent description explaining some of the design issues with the Allis-Chalmers 4-cylinder engines due to their peculiar firing order.
Originally posted by wi50 wi50 wrote:
That answers a lot. If you were to call isky and send them a cam you would not get anything like that grind for a flat plane, 180* Siamese port engine like this...
The way these engines are configured limit the available time we have available for the induction events. An engine with individual ports can tolerate more duration. A 6 cyl Siamese port can tolerate more duration. But a 180* or flat plane crank simply can't. You see there is overlap of the intake and exhaust valves, then there is overlap of both intake valves on a port at the same time that one exhaust valve is open......you wind up with 3 valves open on 2 cylinders opened together. In a sense, to much duration will "airlock" the engine to where it's not going to run well at all.
If you were to call any reputable can grinder or designer, you will get the same story.
The way these engines are configured with the flat plane 180* offset crank and the Siamese port it is hard to run much duration. If it had individual ports, you could. If it were a 6 cyl inline you can run more. But anything much more than the mid 220's @ .050" isn't going to work.
In an effort to wrap my feeble brain around all this, I mapped out the camshaft events on my B-125 engine as follows.
I used the 0.010" lifter rise values.
Edited by Les Kerf - 5 hours 20 minutes ago at 10:01am
