B wheel lock ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: B wheel lock ????
    Posted: 26 Feb 2020 at 1:34pm
Hi everyone.
Have some B,IB wheel locks here, both have same part number on it but look different. The part number is 209128 and one measures 3" L,X 1" W, X 1-3/4" H with 5/8" hole. The other is 3-1/4" L, X 1" or 1-1/16" W, X 1-3/4" high with 13/16" hole. Are these the same or should one have a different part number. And a third one with part number of 210215
Didn't take picture of third lock.
Thanks
Edited by Mikez - 26 Feb 2020 at 1:36pm
shaun44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaun44 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 1:44pm
to be honest i threw those away and bought bolt on rims. i didnt have much luck with those locks and essentric bolts. good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 7:37pm
I think there might have been a couple supplies for that part to AC and the VENDOR had small variations... but same part for same use ? ............ Clamps work GREAT if they fit correctly.. Old worn out need to be built up with weld and resurfaced.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 8:16pm
Probably the same casting but machined different. If I'm thinking right not all the locks on the wheel accept a cam bolt.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 8:50pm
Top one is early b took two of these no eccentric and two with larger hole are for eccentric bolt two of these
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 9:48pm
The eccentric bolts have a 'cross' in the head of the bolt.  I (think) the long leg of the cross went toward the rim, but I'm not sure.  I'd have to check one of mine.
Yes, the eccentric piece(s) went on the rim next to each other and the regular locks and bolt next to each other also.  Bill will probably remember for sure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 10:28pm
Thanks guys. I wasn't going off casting number for part number. One has masking tape with part number an one has allis sticker tag with number on it. The eccentric bolt will only fit through the one with larger hole. But there's not a different number for one or the other.
Thanks
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 9:39am
210215 shoudl be the shraight bolt one, the orange one in pic.
www.awtractor.com
A&W TRACTOR 920-598-1287
