B restoration (24 January 16) Purists Beware! |
Page <1 345 |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Posted: 04 Jan 2016 at 6:26pm |
Thanks R.W. I won't make much of my money back on these restorations whether they were absolutely correct or not. I just love doing it. I figure I might get back 33 cents per dollar spent. I never said I was smart. |
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 05 Jan 2016 at 9:29am |
Steve, HOW do you load that bearing? I don't know what you mean?
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 05 Jan 2016 at 11:07am |
I reworked my 49 B.It was a pile of junk.I customized it some . Fender bad ,gas tank ,front end,grill,hood been shot through,I moved steering ,seat and pedels forward a foot and lowered them about six inches,I made fenders bat box foot rest bumper and three point hitch and twelve volt,Pictures have been on here some time back. Took a year and half and 2800 dollars and now be lucky to get 1000 but I am proud of it .
wbecker
Posted: 05 Jan 2016 at 11:34am |
The front tras bearing is "loaded" by adjusting the number of shims under the cover on the front of the transmission. You don't want it too tight, just a little preload.
Ted J
Posted: 07 Jan 2016 at 6:32am |
Thanks Bill, that helps. Kind of similar to wheel bearings, only with them it is a nut.
i have a first cousin named Bill Becker. Owns Becker Trailer Sales here in West Salem. Actually a quite common name. There are, I believe, at least 3 here on the forum! |
Hubnut
Posted: 09 Jan 2016 at 5:35pm |
1940 B "Lucy"
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 09 Jan 2016 at 6:26pm |
If the black is shiny, as yours is, I don't think it is going to get much hotter then an orange or red gas tank would.
I guess I am a purest but it is your tractor and if it makes you happy, more power to you. (As long as you don't paint it pink, purple or green!) Getting close, good work! |
Allis Express participant |
Hubnut
Posted: 10 Jan 2016 at 4:52pm |
Fired up Haney this afternoon. Runs very good. No leaks--yet. The throttle is really touchy, if I pull the throttle back to idle it dies. On the other end, if I push the throttle forward it revs quickly. Runs smoothly. I guess the low idle needs adjustment. Once I get the bugs worked out I'll put the tin on.
1940 B "Lucy"
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 10 Jan 2016 at 5:13pm |
Is that one front tire to remind you what it looked like before? Looking good glad to heat it is up and running
Hubnut
Posted: 10 Jan 2016 at 5:18pm |
Front end still needs paint. I also have better tires I plan to put on the tractor. |
1940 B "Lucy"
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8570 |
Posted: 10 Jan 2016 at 6:05pm |
Steve,
Glad to see Haney outside and running. You do a nice job on getting these back into good order. Well with the different color combos you cant get them mixed up too easy. You may just need to recheck your throttle linkages all the way to the carb. Very similar to a problem I had on the wide frame WD. Found the rod from the carb to the governor was too long. by .25 inches. Shortened it and had much better results. Are there some stainless fasteners on there? Look good! Stance looks good too. Regards, Chris Edited by Sugarmaker - 10 Jan 2016 at 6:07pm |
Ted J
Posted: 10 Jan 2016 at 9:22pm |
Looking GREAT!!! Haney didn't look that good on the show!!
Hubnut
Posted: 17 Jan 2016 at 4:22pm |
1940 B "Lucy"
Joined: 11 Sep 2009 Location: illinois Points: 88533 |
Posted: 17 Jan 2016 at 5:28pm |
Ya know, I kind of like the color layout......... black hood and tank kind of grows on you.. Sure sets things off compared to solid orange.
wbecker
Posted: 17 Jan 2016 at 5:29pm |
Very nice work! and Fast!
Dan73
Posted: 17 Jan 2016 at 6:44pm |
I like it looks great and will stand out in a crowd.
Ag_F150
Posted: 17 Jan 2016 at 6:45pm |
Awesome paint job on both tractors!( I checked out your C) I really like how you did them up. Makes me want to paint my tractor a different paint job like you did, but I find myself struggling to part with the weathered, faded orange I currently have.😀
beeman
Posted: 18 Jan 2016 at 4:05pm |
Looks good!
Lots of work paid off.
1949 B 3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Posted: 18 Jan 2016 at 4:26pm |
Not stock paint job, but I like it! You did a great job. It looks clean and sharp! Way to go.
Hubnut
Posted: 18 Jan 2016 at 8:46pm |
Thanks for all the comments guys. I put the engine side weights on this evening. I also painted the drawbar. I have to finish rebuilding the mower and get it installed. I didn't keep track of the costs on this one. However, I was more frugal on this build. I'm guessing I finished for around 3-4 K. Still too much for a B, but it's a well restored machine. I've got another B waiting in the wings!
1940 B "Lucy"
Hubnut
Posted: 24 Jan 2016 at 6:20pm |
1940 B "Lucy"
oldways
Posted: 24 Jan 2016 at 8:12pm |
Looks great!
sandman2234
Posted: 24 Jan 2016 at 9:26pm |
Looks great!
AJ missed getting that mower back by just a few days. Let me know how it does when you put some grass In front of it. David from jax |
A proud member of the Allis Express movement!
Northeast Florida |
Dan73
Posted: 24 Jan 2016 at 9:46pm |
That is one amazing looking mower making me wish I had one...
Sugarmaker
Posted: 25 Jan 2016 at 11:22am |
Steve,
Your costs sound about right! Still way more of a mower than a throw away from a big box store! The mower looks good! Are there belt covers? Regards, Chris |
JPG AUSTRALIA
Posted: 25 Jan 2016 at 5:21pm |
looks great,great colour combo.you,ve done a fantastic job.
Posted: 25 Jan 2016 at 6:08pm |
I don't think I have ever seen the belly mower drive pully idler bracket bolted to the bottom of the transmission housing on the final drive case bolts... normally there is a 3 inch box section running between the final drive boxes and bolted to the draw bar bolt holes........ is this standard for that manufacture of mower ?
Hubnut
Posted: 25 Jan 2016 at 6:15pm |
Steve, Yes. This is by the book. I was able to get an original manual for the Arts-Way I372B. I have the original final drive plates for the AC C, and the company no longer makes the B plates. I had to fabricate them. Easy though. The belts and blades are still available from Arts-Way. Even the castor wheels are available. I salvaged one, but had to buy one too. I don't like how far back the chain holder is for the front of the deck. My 59L is more forward and seems better balanced. This thing is REALLY heavy too. I plan to try and fabricate a hand raising mechanism instead of the hydraulic. I still have to finish installation. Steve |
1940 B "Lucy"
Hubnut
Posted: 25 Jan 2016 at 6:17pm |
Chris, Thanks. Glad to hear the WD is running. Rough is better than not. You'll get it. I do have the belt covers. I ran out of time Sunday putting the deck on the B. Tough job by yourself. I'll finish up and give her a spin next weekend. Steve |
1940 B "Lucy"
Page <1 345 |
