B rear splined axle |
TMiller/NC ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1775 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Oct 2010 at 4:47pm |
Has anyone repaired the splines by building up with wire welder and turning back and re-cutting the splines in a milling mach? Will the axle become to hard to work? Will it become brittle or stress crack? Thanks, Tim |
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
I just stuffed in some aluminum shims, OK so far. I have heard that it is usually the hub, not the shaft that gets beat up.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20979 |
I patched one once by grinding off the back side of the hub ( with a hand held grinder) so it would go on farther and added a washer on the outside behind the nut. Just depends how worn things are and I agree, the cast hub is probably worn more than the shaft.
Dr Allis, is the hub cast iron or a weldable malleable ? Thanks, Tim
