B rear splined axle |
   TMiller/NC
   Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776  |
      Quote   Reply
     Topic: B rear splined axlePosted: 04 Oct 2010 at 4:47pm  |
    Has anyone repaired the splines by building up with wire welder and turning back and re-cutting the splines in a milling mach? Will the axle become to hard to work? Will it become brittle or stress crack? Thanks, Tim  |
   Rick of HopeIN
   Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329  |
      Quote   Reply
     Posted: 04 Oct 2010 at 5:02pm |
   I just stuffed in some aluminum shims,  OK so far.  I have heard that it is usually the hub, not the shaft that gets beat up.
      Quote   Reply
     Posted: 04 Oct 2010 at 5:12pm |
   I patched one once by grinding off the back side of the hub ( with a hand held grinder) so it would go on farther and added a washer on the outside behind the nut. Just depends how worn things are and I agree, the cast hub is probably worn more than the shaft.
   TMiller/NC
      Quote   Reply
     Posted: 04 Oct 2010 at 5:58pm |
   Dr Allis, is the hub cast iron or a weldable malleable ?  Thanks,  Tim
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
