B model PTO problem |
outlook6 ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Austin, Texas Points: 64 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Feb 2012 at 7:15pm |
I have two PTO’s I removed from two 1939 B models I parted out with intentions to rebuild one good one. My problem is I cannot get the cam shaft pushed through the drive gear on either one. Per the disassembly instructions in my manuals, I am using a puller that fits. Even with my 200 lbs bearing down on a breaker bar, I cannot get either shaft to budge. Is there something I’m missing here? Can I use heat on these parts? And if so, do I heat the shaft or the gear assembly? As always, any help is greatly appreciated. Thanks in advance. Jim |
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
mild heat should help, on gear only. You want to expand the gear so it will slide off of the shaft. Keep the puller on it.
The book shows a C clip, bearing , then gear. With the clip and bearing removed, the gear should come next. Good luck. Bob Edited by Chalmersbob - 24 Feb 2012 at 10:02pm |
Bob,
Many thanks for the response. Heat did the trick. Now if I can just figure out how to get that transmission main shaft roller bearing out I'll have it made. Thanks again.
Jim
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
I wouldn't put very much heat on it. The shaft is pressed into the bearing. I just press them out. You can rig a bottle jack to press it out with some all thread and bar steel. Or find someone with a press. If you was close I would press them out for you. It only takes a coupla minutes.
