Print Page | Close Window
B model PTO problem
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=46160
Printed Date: 18 Aug 2025 at 12:10am
Topic: B model PTO problem
Posted By: outlook6
Subject: B model PTO problem
Date Posted: 24 Feb 2012 at 7:15pm
I have two PTO’s I removed from two 1939 B models I parted out with intentions to rebuild one good one.  My problem is I cannot get the cam shaft pushed through the drive gear on either one.  Per the disassembly instructions in my manuals, I am using a puller that fits.  Even with my 200 lbs bearing down on a breaker bar, I cannot get either shaft to budge.
Is there something I’m missing here?  Can I use heat on these parts?  And if so, do I heat the shaft or the gear assembly?
As always, any help is greatly appreciated.  Thanks in advance.
Jim
Posted By: Chalmersbob
Date Posted: 24 Feb 2012 at 9:59pm
mild heat should help, on gear only. You want to expand the gear so it will slide off of the shaft. Keep the puller on it.
The book shows a C clip, bearing , then gear. With the clip and bearing removed, the gear should come next. Good luck. Bob
Posted By: outlook6
Date Posted: 25 Feb 2012 at 5:10pm
Bob,
Many thanks for the response.  Heat did the trick.  Now if I can just figure out how to get that transmission main shaft roller bearing out I'll have it made.  Thanks again.
Jim
Posted By: Dick L
Date Posted: 25 Feb 2012 at 5:30pm
I wouldn't put very much heat on it. The shaft is pressed into the bearing. I just press them out. You can rig a bottle jack to press it out with some all thread and bar steel. Or find someone with a press. If you was close I would press them out for you. It only takes a coupla minutes.
