B- manifold studs.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Topic: B- manifold studs.
    Posted: 09 Jul 2010 at 6:30pm
Do the manifold studs on a "B" cylinder head go through to the water jacket?  do they need sealant?
Thanks!
Bob, North Carolina
1949 B
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 7:00pm
2 or 3 of them do.
Charlie
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 7:20pm
None of the heads I have ever worked on did. If the holes go into the water jacket it would be because someone sometime or other drilled to deep when drilling out a broken stud.
Edited by Dick L - 09 Jul 2010 at 7:29pm
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 8:53pm
Thanks Dick L !
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 9:21pm
You can poke a wire or drill bit in each one to make sure someone has not drilled it deeper than they should have.
