B ignition question
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: B ignition question
    Posted: 05 Aug 2022 at 1:17pm
My  ole B  is being ornery, it won't shut off with the on / off switch , i have to choke it off. won't start with the switch in but starts when pulled out.  then won't shut down when pushed in again .  i have a spare switch and it does the same thing.  now what to fix that ?  could it be both switches, one is brand new .  Thanks
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 1:51pm
If you have a distributor, the switch is used to CUT OFF THE POWER to the ignition coil... You can check that the switch is doing that...
If you have a MAGNETO ... the switch is connected to a wire that is on the terminal on the side of the mag... What the switch does is short the wire ( connect) to GROUND and kill the spark...
If your WIRE to the switch is good.......... then YES, your switch is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 1:54pm
you can test the system by using a house light switch or toggle switch and connecting it temporary.......... or just take the two wires off the switch and PINCH them together or apart while wearing a glove.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 6:58pm
Have you installed an Alternator along with a 12 volt battery ?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 6:06pm
it is an alternator gm 1 wire,  the house switch doesn't  work either.I did find i think  on the alternator wiring  there are 2 wires  labeled r 1 and f 2  , i think i have them reversed ,  r 1 is going to the the terminal labeled bat on the alternator f 2 is going to the  the ign switch, it starts and runs this way.  does it make any difference  ?  should i reverse them and see.  it seems to run and charge fine, just won't shut off with  the switch .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 7:06pm
Yes, it makes a difference.. If you dont shut off the signal to the alternator, it can back feed to the coil and keep firing.. you also need a resistor / diode or idiot light in the #1 line.. i guess you have a distributor ignition ?
Edited by steve(ill) - 06 Aug 2022 at 7:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 9:29pm
thank you yes it is a distributor , i will switch the wires tomorrow , if theres no rain they are saying rain, i'll try a light or/esistor as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 10:01pm
