b hydraulic cultivators conversion??? |
   nmwagschal
   Joined: 12 Apr 2010 Location: cincinnati ,oh Points: 20  |
      Quote   Reply
     Topic: b hydraulic cultivators conversion???Posted: 12 Apr 2010 at 8:15pm  |
    Is there any way to convert my manual cultivator lift on my '41 B to use the hydraulic cylinder on the rear to raise and lower the culticators? Looking at it i would think there would be a way , i know i am not the first person to think of this , but i cant seem to find any discussions or pictures about it  |
   Chalmersbob
   Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122  |
      Quote   Reply
     Posted: 12 Apr 2010 at 8:41pm |
   There sure is a way. But it entails about 4 or 5 changes. 1 the rod from the hand lift lever to the rockshaft has to be a male-female 2 piece rod so the hydraulics can lift the cultivator and not affect the hand lift. the 2 springs are removed and only 1 is used on the right, to put down pressure on the cultivators, 3 you will need a C shaped bracket to bolt into the hole where the right spring was removed. it wraps around the shaft and the bar coupling from the hydra ram bolts to it. The factory bar that connects to the rear rockshaft, has a hole in it for the spring to reattach. and of course you must has the rear rock shaft. I can scan a picture from my manual to explain it better.
  Bob
   Chalmersbob
      Quote   Reply
     Posted: 12 Apr 2010 at 8:42pm |
   send me your e-mail address and I'll send you a picture.
   nmwagschal
      Quote   Reply
     Posted: 12 Apr 2010 at 8:46pm |
   i sent you an email
   thanks
   GlenninPA
   Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054  |
      Quote   Reply
     Posted: 12 Apr 2010 at 10:11pm |
   If you get the hydraulic lift kit for the sickle bar mower, it is also the same to lift the cultivators.
  Go with what Bob sends you. Easier than finding one.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
