B gas tank
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: B gas tank
    Posted: 23 Apr 2020 at 3:22am
Hi all i have a gas tank off my B and it has a few dents in it. Am i best to weld a washer to the dent and use a slide hammer to pull the dents or has any one cut the tank in halve just below the rib knock the dents out and weld it back up  any thoughts
Tractors Allis EB,two C,diesel G
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 5:45am
A good bodyman can weld studs, pull with slide hammer, grind off studs. it's a 'stud welder gun', Canadian invention  BTW,... Guy next door does that all the time. New car tin is a LOT thinner than old tank tin !
Edited by jaybmiller - 23 Apr 2020 at 5:46am
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 6:16am
   Be careful welding on a gas tank.
   John C
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 6:38am
You might try using the output of a shop vac to pressurize the tank which might push the dents out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 6:45am
A shop vac can barely blow up a balloon, dents in a gas take a lot of pressure, Fill the tank with water and put it in the chest freezer, then monitor it closely.  I have also use compressed air.  Hook the hose to the outlet, Use a wide ratchet strap around the tank at the cap,   Set it around the corner of a building and with a regulator, slowly add pressure.
This page was generated in 0.039 seconds.
