B/C side mount mower
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Topic: B/C side mount mower
    Posted: 04 Feb 2010 at 1:14am
What is a usable B/C side mount mower worth?  Friend has one that I need to go look at and I want one.  Don't want to rip him off but don't want to overpay either.  I know it has been setting for several years.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 11:49am
Mine came with my C, so I can't say from experience.  But I've read where folks on here have received them for free, or paid as much as $150 for one in good working condition.  Send me a PM if you need any parts, I've parted mine out.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 12:48pm
I've paid anywhere from $33.00 to $450.00 with a running tractor attached to it!
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 1:23pm
My experience is the "free to $150" range. I never bought a $150 mower, but I would think it would have to have everything in tip-top order.
Check the bearing on the tractor end of the pitman, I think last I knew, it was about $225 from AGCO. If that bearing is shot, the price declines dramatically.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 3:24pm
Bear in mind that most of these mowers are VERY worn out and will not perform well without a significant amount of rebuilding and new parts.  Even if it only needs a new knife and a couple of guards, you will have more than $150 in repair parts.  Does this mean that the B/C mowers are not worth messing with?  Not at all.  I took three mowers and probably close to $300 worth of new parts and built one good one that will easily cut through anything mowable in second gear.  It has mown several thousand dollars worth of hay, and I consider it to have paid for itself in the first season I used it.  Don't expect to get the same result with a $50 or $150 mower though, unless you are very lucky.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:55pm
Be sure to get the pulley that goes on the PTO with it, these seem to be hard to find, There are 3 types 1 1/8 ,shaft 1 3/8 shaft sigle belt and the double groove 1 3/8 for the CA mower. These are great mowers, but as stated above you will need parts if you use it. I have 1 I use and 2 for parts 2 were free come and get um and 1 I traded a set ofB cultivators for. Cal in ct
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 9:01pm
I sold one last year for $75.  It was in working condition but it could have used some new sickles as the ones that were on there were dull.  I got it with a parts tractor and the pitman arm had rotted off from sitting so long.  I put a new pitman arm on it and got it all working good, but with the dull sickles, it would jam up from time to time.  I still have a #3 mower that will fit on a B and I have the mounting brackets for it, but I haven't gotten a chance to use it yet.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 9:50pm
Wendel,  Pay close attention to what Brett says.  These are excellent mowers if you want hay.  In fact when we first sold them (1930's - 1950's) they were all we had for any type of mowing, but they required a lot of maintenance to do a good job - guards, sickle sections, ledger plates, hold down clamps, pitman bearing, pitman connecting part, and many others I have long since forgotten.  You may want to consider a rotary style mower.  A lot less maintenance
Good Luck!
Bill Long
