AUGER PTO ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: AUGER PTO ??
    Posted: 30 Sep 2019 at 6:08pm
We Unload wagons with an 8x51 PTO auger with our 180. We bought this auger used and no manual was with it (Mayrath brand).I have been a "stickler" for maintaining 540 on the working tach, but should we attempt to run the 180 closer to "Wide Open" ??
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 6:35pm
Can't say from experience but I've always been told 540 means 540 not 541
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 7:06am
Keep it at 540.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 7:41am
We used to unload into a 8X51 auger that we hooked to our farmall H. We never ran the tractor wide open or at pto speed, we ran the tractor at half throttle. It never had any trouble and was not as noisy. I would use whatever speed you comfortable at.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 7:48am
Many of the old tractors I ran had a PTO Speed on the Tach when equipped. PTO of 540 on my 180 is closer to 1900 on the engine, and is marked on the tach face.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 11:07am
Agreed.  540 or LESS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 3:39am
if you have a spreader in the bin, look while it's working, don't over load it from the auger. we also used an old "H" on our 61 ft auger and ran it about 1/2 throttle, a lot less wear on the auger at slower speeds keeping the flights full.
