Are my front hubs messed up?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: Are my front hubs messed up?
    Posted: 15 Dec 2010 at 4:27pm
This is a follow up to my post yesterday.  The front rim on my D17 w/ loader is going bad.  The rim only has 10 hours on it.  Here is a picture of the hub.  There is a 1/4" groove on the hub where it makes contact with the center hole of the hub.
Shouldn't it be smooth?  Can I fill it in with a mig welder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 4:38pm
Yes, your hub is shot.  It looks like someone ground out around the edge of it for a wheel with a larger center hole, which isn't right.   I will take a picture of a good hub that I have and send it to you.   I do have a good set of hubs here and a good wheel also if you're interested in them.    I will get a picture loaded up.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 4:45pm
Here is a picture of a good hub.   Notice how the center section is even with the dust cap so that there is a good spot for the rim to ride on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 4:47pm
If I were you, I would look at the other one and make sure that one is not modified or buggered up too.   If you need a set, let me know.   I know I have a couple good rims around here.   One or two are a little rusty, but I know I have one good one that must have been a replacement rim as it is like new.   The tire on it is junk though so I would have to demount that.   Let me know if your'e interested.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 5:05pm
i dont know where my dad got them but years ago he repaced our D15 series 2.... hubs and rims with the 6 hole variation .. much heavier
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 5:07pm
D15's came with 6 hole hubs as well as 5 hole, cause the set on my D15 are 6 hole.   Thanks Michael, you gave me a good idea of where to borrow a good set of rims/tires for my D17 so I don't have to buy a new set right away!!
This page was generated in 0.101 seconds.
