anybody have a rule of thumb |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25296 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Nov 2024 at 2:05pm |
for required HP for a given hydraulic pump?
For instance, what would a 2500psi 12gal/min pump require? Edited by LouSWPA - 11 Nov 2024 at 2:06pm |
I am still confident of this;
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54373 |
http://www.metaris.com/hp-calculator.php
17.503 per the above calculator... ![]() Edited by DiyDave - 11 Nov 2024 at 3:19pm |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8665 |
Upsize Lou. Need 50 horse
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
ROT...... you'll need 7 more HP than you've got
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
Not sure what hydraulic suppliers still have charts for that kind of thing. a decade ago Baum Hydraulics , Omaha, Ne. had a chart in their catalog online. Listed gear, vane, piston/ open & closed center pumps. I'm sure there's still a company with a similar online chart. They also had chart showing how much PSI and piston diameter of cylinder to lift "X" pounds.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
When would a hydraulic system ever be operated at full 2500 psi continuously ?? A series four D-17 hydraulic system not doing any work and engine running wide open throttle takes less than 1 HP to circulate 12 GPM of oil at 100 psi. When you hit the end of a hydraulic cylinders stroke and don't let the hyd lever cancel to HOLD, the relief valve opens (2,200 psi takes 15 HP) and then makes the engine labor. So it's only a momentary 15 HP load.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9977 |
0.06 x Horse Power = GPH [approximately]
Edited by Clay - 12 Nov 2024 at 9:44pm |
