anhydrous applicator horsepower
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: anhydrous applicator horsepower
    Posted: 03 Nov 2010 at 8:49pm
 Does anyone know how many shank anhydrous applicator I could pull with a 240 pto hp. front wheel assist tractor? I know terrain and soil type would probably make a difference but its going to be pulled in hills as well as bottoms. Im thinking an 11 or 13? thanks
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 8:53pm
13 with ease
Mark(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 9:16pm
I would say 13 or even a little bigger. The local fertilizer dealership has many tractors running with big applicators. The newer big horsepower row crop tractors seem to handle them with ease. A few years ago one of them was running a FWA AGCO DT 180. Stayed right in there with the Deere. Speed is really the issue.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 11:49pm
My cousin pulls an 11 shank with a 4640 Deere with no trouble.
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 6:29am
should pull 13 easy
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 6:30am
need to remember, You arent chiseling with it, just knifing it in. It is deceiving.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 6:50am
It also makes a difference if you have no til coulters, but you will be able to pull 13 with ease. I pull 13 with my 7060 2WD.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 9:57am
Tried 11 with our 7040 that has been turned up, but it couldn't handle it in all situations.  You probably can handle a 13, just depends how deep you go.  We spring apply below the row, so we go DEEP.
The innovators offer what others will imitate.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 8:41pm
240 hp FWA? 16 or 17 knife easy. I pull 11 with the 7060 and 13 with the 8050 FWA.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 6:20am
I pull 11 teeth with 210 at 8.8mph in sand loam soil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:01am
I used to pull 13 on a 3 point tool bar with an 8640 Deere at about 6.5 mph. The problem we had was getting enough on. We ran 2 control valves at slightly different pressures(6 knives on one and 7 knives on the other) but had to limit our speed anyway.
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 5:59pm
It all depends on the knives and the soil, you could pull 11 mole knives 11" in heavy soil with 240 hp.  We used to pull 19 regular knives 7 mph 6" deep in medium soil with an 8070 FWA.
