Allis Wagons stock number
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Wagons stock number
    Posted: 29 Jun 2024 at 3:28pm
Here are the stock numbers that I have and can verify...Darin...maybe add this to the knowledge base...Mark
300/305    2051528
400/405    2013778
500           2013777
700           2013847
800           2051584
1000         2051547
Missing a 6 Ton
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 4:41pm
I know many people love the AC running gears, but they were not all that good. No way to grease the steering rods was a big mistake. Back in the day, I bought a new 701 gear for a gravity box and within 3 years, you couldn't tow it down the road at any speed. Face the FACTS guys, they were JUNK.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 7:10pm
Who cares if you think they are junk. There are people that think Deere are the best thing.  He wants them and can collect what he wants.  I want ac running gears too and I plan on using them. Their short comings are part of loving the color.
8070nc View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 8:17pm
The steering rod can be fixed very easily with rod ends. Ive got a Allis running gear i made into a header cart. It pulls fine.
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 4:10am
So..what is the point of being negative on this forum...
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 12:16pm
Here’s my consortium of AC wagon gear ID tag info that I’ve collected since 1990s. Any occasion (auctions,private listings, etc…) that I notice an AC gear, I took/copied a photo of its ID tags to begin to understand how Electric Wheel Co.(EWC) manufactured for Allis-Chalmers, Massey-Ferguson, New Idea, Electric, Sears, David Bradley, Montg-Wards, IH, Case, Oliver, Minneapolis-moline, Dakon, etc…
AC wagon ID tag info.
Model, Catalog No. Serial No., Sequence, Wheel hub lugs.
300 cat 2013954, 3 274 (4Lug)
305 cat 2051528, 3 828,1135
405 cat 2013778, 4 148,449,670,1384,1398,2046,(5Lug)
500 cat 2013501, 5 110,458,1776(5Lug)
501 cat 2013846, 5 3849,4648,
505 cat 2013777, 5 2318,2716,2738
601 cat 2013505, 6 373,911,927,1155,1161,1281,3263,(6Lug)
605 cat 2013776, 6 2281,3149,3198,3360
700 cat 2013847, 7 6443,4805,5800,
4456,5037,5034,5103,6566,7556
701 cat 2013920, 7 11889,12059,14042,11482,13356
800 cat 2051584, 8 1093,1590,1616,17xx,
2069,2801,2991,3087,4482,4596,4735,
1000 cat 2013860, 10 135,178,196,324,565,
638,653(mfg1966)(8lug)
1010 cat 2051547, 10 1414,1611,1649,
1698,1775,2346,2405,1569,2356,1243,
1777,1780..
Edited by AC7060IL - 01 Jul 2024 at 2:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 7:27am
Your info is much appreciated....Over the years.. I have most of the literature...contact me anytime...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 11:07am
You’re welcome. It has been a fun journey. So the sequence serial numbers represent each wagon gear within a particular model. For example, my listing for model 1010 contains 12 different gears. The model, cat no., & beginning serial 10 could be added to the last 3or4 sequential numbers to complete each tag ID. Like the following:
1010 cat 2051547, serial 10 1414,
1010 cat 2051547, serial 10 1611,
1010 cat 2051547, serial 10 1649,
etc,,1698,1775,2346,2405,1569,2356,1243,
1777,1780..
So my entire listing, represents 72 different AC gears from the 300 thru 1010 models.
Edited by AC7060IL - 02 Jul 2024 at 1:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 5:18am
Originally posted by Ky.Allis Ky.Allis wrote:
I Back in the day, I bought a new 701 gear for a gravity box and within 3 years, you couldn't tow it down the road at any speed.
What brand/model of gravity box did it carry?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 9:50am
It was a Kory box. Not large by any means and only used while picking ear corn. I know Allis didn't build their wagons. In fact, hardly any major company built their own. I think maybe JD built their own and they were a very good wagon gear. Grease fittings everywhere are the key to long life of any wagon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 11:44am
I acquired an AC 701 gear that the previous owner had installed a Ficklin 300 gravity box that also contained 14" extensions ~ 371 cu.ft ~ 297 bu of grain x 60 #/bu = 17,800 lbs of grain....!  Surprisingly, the 701 gear had held up fine, but the Ficklin box was an earlier version which did not contain extra plating(boxing) on it's C-channel style sills. So it had suffered sill(metal runners) fatigue at each of it's 4 contact points where sills rested on the running gear's front & rear frames.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 3:20pm
Most every company brought their wagon gears from EWC  I've had wagon gears that the ID tag said "manufactured by Electric Wheel Company" but had a big name brand paint and decals. This is also true of the Allis Chalmers gears, the MNI refers the wagon gear part numbers to the EWC factory
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 10:27pm
Interesting discussion.  The stock number on my Model 300=2013997
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 7 minutes ago at 1:27pm
That is different from the 300 2013954 that I located.? Please share a photo of your gear’s ID tag. And I’ll try to do the same.
