Allis type B lack of power problem
alan22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan22 Quote  Post ReplyReply Direct Link To This Post Topic: Allis type B lack of power problem
    Posted: 22 Nov 2010 at 10:06am
Hi,
Can anyone help with this problem. My 53 allis type B (UK built) idles just fine, but as soon as you throttle up and put it any load on the engine, it just dies. Have completely rebuilt and cleaned out the fuel system and carb but has made no difference. any help appreciated.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 3:59pm
With everything assembled, do you know for sure you have a good flow of fuel to the carb bowl?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 5:28pm
or is it a timing problem where you have not spark advance when the motor speeds up ?
AC Tundra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Tundra Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:36pm
plug wires crossed?
What do you mean another tractor, honey? That tractor has been here for years.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:41pm
Yeah check the firing order, trust me your problem sounds very, very familiar. I spent several days spread out over several months figuring that out. oops.
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan22 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 3:22pm
Thanks everybody for all your replies. Have checked out firing order and it is ok. The model I have is magneto ignition, is the ignition auto advance built into this? (not too familiar with magnetos). Fuel up to carb and seems to be through to manifold. Throttle seems to work and the revs increase when this is opened. As soon as I engage drive and release the clutch, the engine just dies. Could a blown gasket or faulty piston give this sort of trouble? Beginning to wonder if this is something serious.
Cheers
Alan22
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 3:57pm
I would now suspect the governor is not working properly, kinda like the trouble we have had in the State of Illinois in the last several years. It might not hurt to check for manifold leaks with a can of WD40 or brake clean.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 6:35pm
Will it run wide open just sitting for several minutes?
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 6:52pm
I would check the air breather mighthave mud dobber nest in it. Have a C that would die as soon as you throttled it up and that was the problem
