Allis two row planter model?
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: Allis two row planter model?
    Posted: 24 Jun 2017 at 8:23am
Can anyone tell me a lil more on this planter? Some of these have tapered seed cans.....smaller on bottom than top. Am i to assume this is pin hitch....prob for a ca or wd? How many different seed plates could these have come with? Mainly just corn and beans?
Thanks!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:39am
Don't know about the seed cans being tapered. I know some have tapered fertilizer and some newer had fiberglass fertilizer
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:50am
This guy has a pile of seed plates...could they all be for this planter? Is that possible?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:52am
If those seed plates are all for this 2 row id imagine that its pretty tough to find that many for it....or arent they to tough to come accross?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:53am
Says there is 15 to 20 plates but doesnt know much about it and is unsure if they are all for it.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:56am
I planted many an acre with that exact planter on a WD. Father bought it new in 1950, the drawbar fits into the plates with the hole in and the front bolt is taken out to mount and then put back in between the top and bottom drawbar peices. You let the drawbar swing and remove the two pins in the bail so it can be lifted up and let down. Don't know the model number and made a four row with another planter and a toolbar years latter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:58am
Those are all AC plates and you can get plastic inserts to also use JD plates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 9:16am
Ok. What seeds do u suppose those plates would all be for?
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 9:46am
You need different size plate for different size seed or different crops depending on what he wants for them they might be a good deal on epay there 10-20$ a set I've seen both used on back for fertilizer but tapered cone seems to be more common
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 9:53am
Agree with Nick, different size seed needs plates to match the seed size.
Looks like corn and bean plates are all there for that planter.
I vaguely recall dad planting milo (maize) with this type of planter but I'm not seeing plates for that.
Edited by Jim Hancock - 24 Jun 2017 at 9:54am
How blessed we are by HIS GRACE!
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:00am
Thanks!....This is a mounted non snap coupler version.  As pictured, designed to fit Allis Chalmers only.  Early 1950 version...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:03am
Thanks for all the great responses guys! You say all of the Corn and bean plates are there for that planter.... excuse my ignorance but shouldn't there be one size plate for beans and one size plate for corn and there is only two rows so why so many plates??
Also could a person put that planter on a CA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:37am
It will go on a pin hitch ca all corn seed is not the same size there is also round and flat corn sometimes it says round or flat on bottom of seed plate there are different size plates to match seed size and to maintain planter accuracy id suggest getting a Manuel it explains a lot about these old planters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:48am
Good thought on the manual.
Well i told the guy id take it. I may have paid to much for it. 500.00. I would love to completely restore it this winter. He said zero rust in the cans...any dark spots on it are from it being oiled up and then a lil dirt on top. I will post a progressive post w pics when i start on it this winter. Should be fun:)
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:51am
Seed corn comes in many different sizes.  Also, flats and rounds.  I'm sure my dad has at least 10 different sets of plates for this planter along with a set of soybean plates.  (The soybean plates don't measure individual seeds..just several at once).  We always used JD plastic plates with the adapter inserts.  The planter was $40 at the auction where my dad bought it.
[TUBE]43c1aQGaC5w[/TUBE]
Edited by DanD - 24 Jun 2017 at 10:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:57am
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:57am
That is the planter I sold.  Worked fine.  See if you can get a manual.  They will have a better explanation of the plates and various settings.
AC used that planter for years till it came out with the All Crop Planter then moved to the no till.
As stated above the four row planter was two of the same planter with a tool bar for mounting.
Can't believe how good a shape it is.  Usually the fertilizer tins and even sometimes the seed cans are rusted through along with other rust on the entire unit.  I am really surprised at the excellent shape of the planter.
I do not know the price but for that good shape, to me, $ 500 does not seem like too much.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 11:15am
As for the history of this planter....the fella that owns it said his grandfather bought it brand new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 11:28am
Get those extra seed cans and fert cans if nothing else you can use for parts or sell later markers too
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 11:29am
Define a "Set of plates" that would be two correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 11:47am
Some seed corn companies put the plate number on the seed corn bags
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 11:47am
They have numbers cast into the bottom of plate a set is typically two for a two row
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 12:45pm
Here are examples of common sizes of John Deere plastic plates for corn.  Seed corn bags will usually suggest which plates to use for IH and Deere planters.  Don't usually have Allis plate numbers.  Can use the Deere plates in AC planters with adapter.  Also notice that each plate is different color for quick ID.
Edited by DanD - 24 Jun 2017 at 12:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 12:48pm
Very nice collection of plates!
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 12:51pm
Not mine.  Just found on internet.  My dad has more than this though.
Here is the adapter to use JD plates on AC planter.   Is useful because you can find JD plates anywhere and the corn is marked for the JD plates as well.
Image result for adapter allis planter deere plates
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 4:44pm
Usually bean plates have way more seed sells to get up to the population you want. Corn ones also can be different seed sell count, usually 16 or 24 to give more population options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:02pm
That looks like the wd drawbar hitch, not pin hitch.  You take the drawbar bail off, and insert the DB, under that front bolt, then put a regular DB pin in at the back hole.  As for the plates, it has been covered pretty well. each seed population, and each size of seed means a different plate.  Multiply that by years of farming, using seed of different manufacturers, can yield quite a large collection of plates...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:14pm
That makes perfect since. I can visualize that mounting on the drawbar when I look at the hitch on the planter.
This page was generated in 0.438 seconds.
