allis swing cylinder |
kansasbikerider
Topic: allis swing cylinderPosted: 21 Aug 2013 at 2:43pm |
needing a swing cylinder for a allis chalmers 816 b series 2 backhoe..called and checked every where a I can with no help.. anyone got one they wanna sell.. I can buy all the parts for a complete one but cost is way out there...understand there may be a case swing cylinder that may be the same specs,, I think its a case 580c but not sure..any help would be great thx Kelley 785 531 1141 or kansasbikerider@hometelco.net
agent008188
Posted: 21 Aug 2013 at 6:28pm |
I can rebuild your cylinder and help with parts. give me a ring 785-633-4377
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 21 Aug 2013 at 6:58pm |
Is it two cylinders mounted under hoe or is it a rotary piston like on the 615 hoe ?
MINNPAR should have the repair parts or if cylinders a hyd shop should be able to obtain generic parts for most repairs . IF they are missing - well good luck in trying to find original replacements
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 21 Aug 2013 at 7:11pm |
I use KwikParts in Williamsson(burg) Missouri. They service Allis and Case, and get your stuff to you fast. They last got me the lift cyl packing for my 420 Backhoe, genuine CIH parts.
doctorcorey
Posted: 22 Aug 2013 at 10:37am |
I think yesterday I saw a case 580 swing cyl on the web. Walt's Tractors, I think.
kansasbikerider
Posted: 22 Aug 2013 at 6:18pm |
min par didn't have any thing but looking at all my options will try some of the places u all have posted thx for the help so far it all helps
kansasbikerider
Posted: 22 Aug 2013 at 6:19pm |
it is 2 cylinders the turion type
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 22 Aug 2013 at 8:09pm |
Dont know where in KS you are but i would try Ginder Hydraulic Salina KS can repair pretty much any hydraulic cylinder, they also fabricate cylinders for custom needs
doctorcorey
Posted: 22 Aug 2013 at 9:41pm |
Sorry, that should have been Maine Tractor. Case part no. D36878. "580 swing cylinder" at 300$ Did you ever mention just what is wrong with your cylinder? Or is it missing?
![]() Edited by doctorcorey - 22 Aug 2013 at 9:42pm |
kansasbikerider
Posted: 22 Aug 2013 at 10:54pm |
m y left hand cylinder was bent in the shaft and the last 3 - 4 inches is the vavle plate and spring called the cushioner and it broke there and ruined the whole cylinder
kansasbikerider
Posted: 22 Aug 2013 at 10:56pm |
im only about 50 mile from ginder hydraulics thought about hoff machine in salina when I get the chance im taking both cylinders and let them take a look being one is still good
