Allis snap coupler disk ?
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Allis snap coupler disk ?
    Posted: 02 May 2011 at 8:25pm
I'm needing information on the lift chains for an Allis snap coupler disk.  If anyone has the lift parts for sale let me know, other wise if someone could get me some pictures and a measurements it would sure would be appreciated.
 Thanks,
 Joe
Life is simpler when you plow around the stump.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 5:54am
What model, Joe?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 6:16am
My old WD 8' disc had a twist chain on R/L side up to a small lift bracket that bolted to lift arm's. I have 1 bracket available for sale. Chain is/was 3/8" dia +/-.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 11:47am
Im not sure what model it is, but when I get it home I will take a picture.
 Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:29pm
Heres a few pictures:
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:35pm
That's a 200 series. The traction booster setup will be the same for all of them. I took mine off because it makes the tractor impossible to turn when the disc is up. At least you have the pulley. That is probably the hard part to find. There is a bar that goes between the lift arms with lift arm latch bars on it. The chain runs from one end of the bar to the other through the pulley.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:28pm
Here is a picture of what you are looking for. this is on a grain drill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 6:08am
Joe...I might have the chain, but not the bar. I'll look and let you know.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 6:33am
I have one like that. They were also availible as a pin hitch.
roadrunner(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 6:34pm
Joe I have the whole thing you need, chain and bar. I'll swap for whatever you have laying around or 20.00.  260-849-0260
This page was generated in 0.158 seconds.
