Allis HD 11 EP oil around starter
mlfcow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlfcow Quote  Post ReplyReply Direct Link To This Post Topic: Allis HD 11 EP oil around starter
    Posted: 25 Nov 2011 at 10:37pm
I have oil leaking around the soleniod on the the starter. This happens at cold startup, after the machine runs for few minutes it stops. Once the machine is warm it can be started and stopped with no problems. I plan on changing the trans filter, thinking a dirty filter may causing a restriction with cold oil. I also plan on changing all trans and torque converter fluid at the same time. I have an info that says the oil should be "ATF type C  Shell Donax T-5 Diff oil" is this correct. My shell dealer is checking into this for me to crossreference a current oil. The person that owned it before me was using Tractor Hyd Fluid. I suspect this may have been the wrong oil and may be my problem.
Any help or info would be appreciated
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 3:15am
ATF 10W is the correct oil. Make sure it is no heavier than 10W. Is your tractor post number 13366 with Rockford wet flywheel torque converter, or earlier with Twin Disc dry flywheel converter
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlfcow Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:51pm
mine is a 13585. dont know which torque it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:03pm
Will be Rockford wet wheel converter then. A little sepage out your starter is no real worry when your flywheel housing is supposed to have trans oil in it.
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 7:26am
 I HAVE A HD11EP  SN 13204 AND IS SUPPOSE TO HAVE THE TWIN DISC CONVERTER BUT HAS THE ROCKFORD AND MINE WAS LEAKING OIL AROUND THE STARTER AND I FOUND THE PLUG ON TOP OF THE STARTER LOOSE.
giz's hd-6ep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote giz's hd-6ep Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:32pm
o- no i'm using tractor hydraulic fluid in mine, is that the wrong oil if so what should i be using ??
