Allis G brakes, adjustment
Alexander View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Topic: Allis G brakes, adjustment
    Posted: 23 Jun 2011 at 1:46pm
I have two Allis G tractors.  The brakes on both of them are barely effective, and it is becoming hazardous.  I went through this some time ago, and what I learned is that there is a steel rod which attaches the brake pedal to the brake lever at each wheel.  At the wheel end of this rod, there is a threaded yoke, which may be used to adjust the brakes.  However, now the rod has reached the limit of its travel, and while I could cut the rod in order to tighten it further, it seems that might not be smart.
I'm wondering if it is time to reline the brakes.  Any thoughts?
http://s1217.photobucket.com/albums/dd392/althorp1/Allis%20G%20brakes/
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 3:30pm
Sounds that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 4:14pm
OK. Any thoughts on where to source the needed parts, or would it be better to find a brake shop. Thanks!
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 4:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 5:23pm
Best to try the guys that advertise here first to check prices(including shipping...) then call a local brake shop and get a quote.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 5:34pm
I stock the  reline kits $26 per  side  with rivits. Can put in mail tomorrow.  Tony
www.tonystractors.com         1-877-602-3994
Jason in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason in MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 5:35pm
Whoever my grandfather bought his g from years ago did just that, cut the brake rod and welded it together. Once i put new linings on, i could barely get it threaded back on there as it was almost too short so i would not recommend cutting. I redid both of my linings in about 2 hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 5:38pm
Tony's Tractors has em' in stock. Got em' for my G when I was restoring the back half of the machine. Get the brake hardware to. Mine was worn out.
Steve@B&B
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 7:37pm
  we have linings in stock   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 9:30pm
Thanks for all the suggestions and pictures to boot!  I'll pick up a set of linings and take it from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alexander Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 9:33pm
By the way, what's involved in riveting the linings to the steel backing?  I assume I will need to find a rivet installation tool?  I've got a couple of rivet tools in the shop  - wonder if one of those will work....
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 6:31am
The one I use looks an awful lot like this rascal.
http://www.aircraftspruce.com/catalog/topages/RapcoBrake.php
This page was generated in 0.270 seconds.
