Allis G brakes, adjustment |
Alexander
Topic: Allis G brakes, adjustmentPosted: 23 Jun 2011 at 1:46pm |
I have two Allis G tractors. The brakes on both of them are barely effective, and it is becoming hazardous. I went through this some time ago, and what I learned is that there is a steel rod which attaches the brake pedal to the brake lever at each wheel. At the wheel end of this rod, there is a threaded yoke, which may be used to adjust the brakes. However, now the rod has reached the limit of its travel, and while I could cut the rod in order to tighten it further, it seems that might not be smart.
I'm wondering if it is time to reline the brakes. Any thoughts? http://s1217.photobucket.com/albums/dd392/althorp1/Allis%20G%20brakes/ |
Tedin NE-OH
Posted: 23 Jun 2011 at 3:30pm |
Sounds that way.
Alexander
Posted: 23 Jun 2011 at 4:14pm |
OK. Any thoughts on where to source the needed parts, or would it be better to find a brake shop. Thanks!
Goose
Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Posted: 23 Jun 2011 at 4:16pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25243 |
Posted: 23 Jun 2011 at 5:23pm |
Best to try the guys that advertise here first to check prices(including shipping...) then call a local brake shop and get a quote.
Tony.Or
Posted: 23 Jun 2011 at 5:34pm |
I stock the reline kits $26 per side with rivits. Can put in mail tomorrow. Tony
www.tonystractors.com 1-877-602-3994
Jason in MO
Joined: 21 Feb 2011 Location: SE Missouri Points: 169 |
Posted: 23 Jun 2011 at 5:35pm |
Whoever my grandfather bought his g from years ago did just that, cut the brake rod and welded it together. Once i put new linings on, i could barely get it threaded back on there as it was almost too short so i would not recommend cutting. I redid both of my linings in about 2 hours. ![]() |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 23 Jun 2011 at 5:38pm |
Tony's Tractors has em' in stock. Got em' for my G when I was restoring the back half of the machine. Get the brake hardware to. Mine was worn out.
Steve@B&B |
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 23 Jun 2011 at 7:37pm |
we have linings in stock 1-800-254-3116
Alexander
Posted: 23 Jun 2011 at 9:30pm |
Thanks for all the suggestions and pictures to boot! I'll pick up a set of linings and take it from there.
Alexander
Posted: 23 Jun 2011 at 9:33pm |
By the way, what's involved in riveting the linings to the steel backing? I assume I will need to find a rivet installation tool? I've got a couple of rivet tools in the shop - wonder if one of those will work....
Roddo
Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Posted: 24 Jun 2011 at 6:31am |
The one I use looks an awful lot like this rascal.
http://www.aircraftspruce.com/catalog/topages/RapcoBrake.php |
