Allis cs
SCOOTER99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCOOTER99 Quote  Post ReplyReply Direct Link To This Post Topic: Allis cs
    Posted: 27 Mar 2012 at 11:40pm
I have a 1953 ca and need to know what the hitch is suppose to look like I need to see pictures can anyone help me
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:02am
There are a couple different styles that were available on the CA's. I don't have any pics but someone will, maybe Bruce or Mark willl have some, they are your neighbors up there. Does yours have a regular drawbar or a snap coupler or is it all missing?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:38am
53 should have a pin hitch. I'll try to get a picture after the sun comes out. The lift arms point straight down and a cross bar pins to them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:02am
Here is a snap couple set-up which started in 1953. The lift arms are shorter and the bail isn't attached to the the lift arms.
The pin hitch drawbar pinned under the bell and pinned to the lift arms after they were set vertical.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:59am
In Charlie's picture of a CA 'Snap Coupler' set-up, 'Lift Arm Latches' would be installed
on the outer end of each lift arm to complete the 'Snap Coupler Hitch' set-up.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCOOTER99 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 8:41am
My setup is not like that I took a pictue I dont know how to upload it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 11:28am
backed the tractors out and took a couple pictures this is the older pin hitch. thie tractor is an early 53. the later tractors had the snapcoupler setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 11:30am
Here is the pin hitch set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCOOTER99 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 10:30pm
Those pictures helped thanks
New question 3 gear is out do I have toreplace both gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:37am
If things aren't too bad in the tranny, you might not have to replace any gears. the collar is all that is shifted and if it has most of the wear, the tranny might work for a long time with it replaced and slop taken out of things. It's kinda a wait and see thing till you tear it down and inspect everything. The more times 3rd is used and pops out , the worse the spline on the gear and the more chance of having to replace it $$$$$.
