allis chambers disk
hgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hgreen Quote  Post ReplyReply Direct Link To This Post Topic: allis chambers disk
    Posted: 25 Apr 2011 at 8:35pm
Have been looking for bearing and bearing housing for heavy duty Model 200 disk.  The one I have is the 8' model but has the heavier duty bearing housing and bearing.  The axle is square and is approximately 1  1/8 in. in diameter and the bearing diameter appears to be approx 3  1/8 in.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:18pm
think IH uses the same thing, i was able to match the bearings on my 2600 disk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hgreen Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:12pm
Thanks for the feedback, I'll check into that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hgreen Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 9:25pm
I've found the bearing, NTN makes one that matches the ones on the disk, but they don't make a housing for it.  PEER bearing makes a housing (called Tillage Trunnion Unit), but they only make one with an axle diameter of 1.5" which is too large.  The axle on my disk is about 1 1/8 " and the housing is 4 inches.  Does anyone on the forum have a housing which will work with the bearing.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 11:21pm
Have you looked at shoup?  here's a bearing from a Kewanee disc like we run.   http://www.shoupparts.com/DS208-TTR8/     -Wes
This page was generated in 0.049 seconds.
