Allis Chalmers WD45 Diesel project
 Post Reply Post Reply Page  <12345 8>
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 7:49am
I rebuilt the gearbox, (seals, bearings) on my Dixie cutter, it was NOT fun. Bearings came off the shaft with a cutting torch. Had to put the shaft in the freezer and heat the bearings in the oven to get it back together.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 8:41am
Sounds like a good idea Sugarmaker
The gearbox is nice and snug so don’t think it needs bearings just seals (it leaked all the oil out).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 12:02pm
I have the snap coupler version of that mower. You can get the seals from Agco still, that's where mine came from. The bolt on the blade adapter is a left hand thread BTW...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 6:35pm
Got to looking at the gearbox , it is different than the one on AGCO’s website. Also learned that Allis has two different places make them. https://na.apb.agcocorp.com/p/agcoallis/9001526b/l/31?tocGuid=20536ac1-47fa-3055-d958-3c34fd356ef5
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 8:57pm
Yes you're right, as near as I can tell the 160's were made by Danuser machine works,like yours is, and the Allis Laporte plant.Laporte built units have the two ribs that run front to back on the deck.The Danuser built units had the two angle iron pieces that ran side to side like yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 11:07pm
Do they have a special parts catalog book for the danuser?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 12:11am
It doesn't look like it.Here is a link to an ebay search for the manual for your mower.Looks like one can be had for $12.00 bucks.It has the parts list in it.Maybe get the manual and then cross the seal numbers to get what you need.Hope this helps.  http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=allis+chalmers+160+rotary+mower&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=160+rotary+mower
Edited by ac45dave - 28 Aug 2020 at 12:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 2:41pm
My cousin has a manual for it, he has been giving me part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2020 at 10:30pm
I got the gearbox back together and put on. The bottom side bearing was cracked so I figured out AGCO can’t get no info on them so I took the gearbox apart and took it in to my local black smith and he found a replacement bearing that fit nicely then had to replace a tire and jacked it up and the wheel bearing was rusty so than had to get those wheel bearings, so far I’m waiting on a sleeve for the wheel bearing seal.
Thought I would post a update to show the slow process on it.
It should be like a new one now!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 6:40am
55,
 You have been busy! The brush hog will be a nice addition and a real work horse.
 Thanks for the update. Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 10:03pm
Got it back together today and mowed a little bit with it and loved it!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 7:53am
55,
hummm? picture may not be the one you wanted to post?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 8:22am
Oh yes it is. That’s a quick job of mowing sorry for the poor quality, it was at evening
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 6:58pm
Had to put new knuckles on the mower. Got them from a local John Deere dealer so now it has Deere parts on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 10:26am
Ok now I’m back.
I mowed a 15 acre patch of CRP ground with that little 5foot mower and my wd45 and well it started blowing antifreeze out of the overflow hose so I quit for lunch and came back after it cooled down, so I started it with the radiator cap off and everything seemed fine but as so as it hit 150 degrees it blew antifreeze all over again. So after thinking the thermostat could be sticking I taped on it and it quite doing it.   So going to torque the head down again after I bring it back and see if that helps.
If anyone has any other ideas of what could be going on please post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 12:34pm
If it's over full it will puke out the excess when warmed up. As long as you can still see it above the tubes you got enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 12:56pm
It was under the hoses in the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 6:21pm
Ok I checked the head bolt but they was all good, it now just over heats but the radiator is cold.
I am thinking the water pump is air locked. So I left the radiator cap real loose for this night. Tomorrow I will see if it made any difference. Also painted the pipe on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 5:49pm
Now I think it might have a bad head gasket. It is foamy in the radiator. Does anyone know where to get a Copper head gasket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 9:15pm
Got the head off of it and the head gasket looks fine but the head has a bunch of cracks around the intake valve.
If you look closely at the picture you can see the cracks.
Edited by 55allis - 03 Dec 2020 at 9:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 9:16pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 8:16am
Why do you want a copper head gasket? If the sleeves are low, a copper gasket won't help.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 8:28am
Ok now with a update.
Found a guy who makes copper head gaskets so I’m having him make me one. Now the problem is finding head bolts that are not too expensive, I call my Agco dealer and they said it was $1600 for a kit so a little too much $$$$ for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 9:31pm
Someone here has a list ( I think) of ARP bolts you need. Much less than AGCO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 10:51pm
It would be very much applause if any one would know and post about it.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 2:54am
I got studs for my series 4 diesel from Pfouts Family Farm, good people to work with and good service as well!!
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 7:26am
Originally posted by 55allis 55allis wrote:
Isn’t it a high pressure lower volume? Thought if I could add more hydraulic oil to the system it could pick up things that take more oil.
in my experience with these hydraulic systems on any of my WD's when you over fill them they air lock and quit working so adding another tanks will definitely cause this to happen and dads had it happen on his 45 as well
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2021 at 2:13pm
I ordered all studs, nuts ,and washers for the head for $250 so not as bad as agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2021 at 2:14pm
And that was from ARP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2021 at 6:16pm
