Allis Chalmers WD45 Diesel project |
Post Reply | Page <1 45678> |
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 545 |
It has less than 50 hours on a complete overhaul. It had a d17 overhaul kit put in it.
ac45dave
Orange Level Access Joined: 23 May 2015 Location: SE(IN) Points: 1319 |
Well that may be but it will still have to come apart to address the counter bores.What was done to the block when the d17 kit was put in it?Doesn't sound like the counter bores were done properly otherwise your sleeves would have stand out above the deck.
festus51
Orange Level Access Joined: 26 Mar 2017 Location: Osage City, KS Points: 1639 |
Some one ruined a WD-45D
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
MACK
I can sell you a set of fire rings that will seal it up if you have some one qualified to put them in and properly torque it down. MACK
Orange Level Access Joined: 12 Sep 2009 Points: 19504 |
Brand new sleeves (with a crisp sharp lip on them) probably did stand up a good enough amount when installed in a worn out block counterbore. But, as soon as things were torqued down and the engine run for a time, the sleeves have now settled down into the worn counterbore ledges. Now, you have head gasket blowing problems.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3734 |
pull it down and have the block decked and all bores cut to get +.004 on all sleeves or you are wasting your time
Edited by CAL(KS) - 03 Mar 2021 at 8:09am |
55allis
Is there a way to “shim” the sleeves up?
A shim on an old, worn and non-square counterbore is a waste of time.
ACjack
Silver Level Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 263 |
I'll throw my 2 cents in here. At the plant the height of the cylinder sleeve in relation to the block was referred to as cylinder sleeve protrusion. The Doc is correct on the .003 / .005 spec above the deck surface. Simply measure from the very top of the sleeve down to the deck surface. the best tool to use is a depth micrometer.
Another thought on how to achieve this dimension other than thicker fire rings (most effective) or redecking the block is what we used on the V12 engines when we started production of that engine and that was the use of shims. When measuring the protrusion take you readings from at lest 4 or more spots around the sleeve.
Edited by ACjack - 03 Mar 2021 at 9:14am |
ac45dave
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
I got some old sleeves in the shop I should go "measure the width of step on liner. IT AIN'T MUCH!!!! As Doc says,they are so skimpy shimming would be a joke. Sorry Jack but that won't work on these.
Edited by SteveM C/IL - 03 Mar 2021 at 8:03pm |
55allis
Put a oem gasket on with hylomar and it works so far so good!!! No dislikes on antifreeze.
55allis
Also figured out that if you put a Magnet heater on the intake Manifold it will start much better.
55allis
Had it running for about 2 or 3 hours and no problems.
Found a hour meter I think goes to wd45 diesel but it is 6 volt |
SteveM C/IL
Can you add a resistor to knock it down to 6 volt ?
55allis
55allis
Hooked up a Allis Chalmers 3-16 plow today and plowed half the day. Only problem I had was it barely started in the morning after a hour of being plugged in and a little starting fluid. Can’t figure out why it won’t start very good when it’s 40 degrees out.
After all the head gasket troubles and knowing that you have a couple of sleeves not sitting up where they should be and you plow with it ???
55allis
Yep, it pulls really good in 2nt gear (it runs quite fast for a 45) which I think is between 5 and 8 mph. In 4th it goes between 18 and 22 mph.
55allis
I think I figure out what was wrong, one pair of valve was out of adjustment. I took it apart and torque the head to 105 ft lb and adjusted/ checked all the valves. I did get it back together and started it which was a lot better. I’ll see if it will start tomorrow afternoon and see if it fixed the problem.
55allis
Here’s what I’ve been doing lately with it.
55allis
Don’t know if this worked but thought I would try to post a video.
55allis
Sorry, guess it didn’t work.
55allis
Edited by 55allis - 06 Apr 2021 at 10:06pm |
55allis
I did some tire painting today. Got silver tire paint from Amazon.com for $8.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3282 |
good photo with the disc hooked bet theres no wheel slip with all that rubber
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11549 |
LOL! This guy has got everybody scratchin' their heads...... LOL! How did Foghorn Leghorn say it? "Nice boy, but don't listen to a word ya say"...... I've had my share of customers over the years in the electrical field do the same thing. It'll eventually come back to haunt him again. Usually things like that become "hand granades" later on when not done correctly the first time. Sorry to say but that's what happens.... Steve@B&B
55allis
Well now I’m back again with another problem...
And not with the engine but the clutch... Well as the story goes I was sickle mowing with it cause I like the speed of it and just got back from a 2 mile drive and was getting ready to go for a 5 mile drive to another farm and well I replaced a guard on the mower in the shop and went to drive it out, well it made a “thunk”,rolled out and stopped... |
If the PTO and hydraulic pump won't work, the foot clutch has failed.
55allis
I think well it is apart, I will rebuild/replace the hand clutch since I know that it doesn’t have any shims left.
Does anyone know of a place that would sell just the pads for a fair price? Other wise I might have access to a parts Wd that’s all ready apart. |
