allis chalmers hd 16 dp buda 844 engine
 Post Reply Post Reply Page  <1 234
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 10:57pm
The most reasonably priced engine for re-power would have to be a Detroit 671 inline. Being that they were used in the earlier HD16's it shouldn't be too hard to do the retro-fitting.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 3:37am
Eric
IIRC those were last used by Allis in HD15's and not HD 16's?
If they didn't have torque converters and power shifts 6/71's might be in a similar position as the Van Natta conversion attempt
russell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russell Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 5:28pm
Thanks for the info
The 16 dp has a converter
i did not think of the wet fly wheel and also the twin pickups in engine  sump
a conversion would be difficult
will have to dosome more thinking
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 10:50pm
Ian: Thanks for correcting me on the 671 Detroit being in the early HD16. A number of years ago there was a local HD16 here (Canada) that had a 671 in it. It was obviously a retrofit. From there came my assumption.
Stewart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stewart Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 9:56pm
I use a Hd16 around the farm that is powered by a Detroit 671 , the hole through the hood where the exhaust used to come through had a rough patch welded in , made me think right away it wasn’t the original engine. The old girl can sure push dirt . Need good bearing protection or you’d be deaf in no time .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stewart Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 10:00pm
